Click here to go to the first RED TEAM post in this thread.   Thread: Playback - Codec Error?
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1 Playback - Codec Error?
    What causes this? I am guessing overexposure, I saw that was mentioned on another thread but I just want to confirm.
    I was shooting the setting sun, it was behind a bunch of houses. Not serious footage, just testing the camera.
    "Four Years" - a 35mm short film - http://vimeo.com/3071939
    REDuser Sponsor Brook Willard's Avatar
    Burbank, CA
    What build? Older builds would have codec errors with significant overexposure, but that problem was solved many builds ago...
    Just got the camera a couple of days ago. Build 12.
    Senior Member David Birdy's Avatar
    Dec 2007
    Jim,
    Build 12 is the most recent ..so you may need to download the firmware from the NET
  5.   This is the last RED TEAM post in this thread.   #5
    Please email this in to tech support so we can get to the bottom of it.
    Graeme
    www.red.com - 5k Digital Cinema Camera
    Science enables stories. Stories drive science
    FLUT™, Image Processing, Colour Science and Demosaic Algorithms, REDRAY 4K delivery
    Senior Member I Bloom's Avatar
    Jan 2007
    Manhattan
    Did the problem happen during recording or on playback?
    Quote Originally Posted by ibloom View Post
    Playback.
    I sent in a help ticket.
    Jan 2007
    Manhattan
    Quote Originally Posted by Jim Exton View Post
    Playback.
    RedAlert should be able to play the full clip. The camera is less fault tolerant on playback I noticed.
    Update - For whatever reason, it works now.
    Camera was powered down for an hour. And before it went from outside 50 degrees to inside 71 degrees.
    That is the only difference I can think of between the two times I played back that card.
    Jan 2007
    Manhattan
    It's probably worthwhile to help them trace the bug by narrowing down the circumstances under which the problem occurred:
    Is there something visible in the R3D file around the time frame that the playback mechanism triggered the codec error? On footage I shot using build 10 I had a similar problem, which I attributed at the time to cold weather, in the footage you can see sections of the frame where it appears that compression couldn't complete. In retrospect, I was also dealing with snow on the ground, which caused some areas of overexposure. This is what it looked like:
    Attachment 2385
    My assumption was that this was a cold weather thing and fixed in the new bodies. But maybe something else has been slipping through the cracks. One other question, were you using False color, around or during the time of playback?
