i need to rename an xml the .mov files to r3d
clipfinder is no longer available, anyone that can help?
thanks!
PP
thanks!
PP
What about using RCX pro? As Hans Georg suggests here:
http://www.daun.ch/hamingja/
Too bad, by the way...
I used to use text wrangler, available on the Mac app store, to do that before clip finder did when that fixed the looping bug in color a long time ago.
Just use the search and replace function of that or any text editor that will allow you to save as whatever file extension you choose.
Tim
it wont do it... i need to go from FCP to adobe premiere an replace de .mov with R3D, final cut is giving me too much problems... premiere is editing the r3d very smooth... but i just need tha in between process
the thing is that is a long feature... it would be a lot of renaming to do
You can have it automatically rename all instances of .mov with .r3d . Should take less than a minute.
Tim
find/replace...
Forklift 2. Well worth $29.95 for all-around file work.
http://www.binarynights.com/
Mike
