Thread: Can a Panasonic 7.9" monitor with with Epic?
Results 1 to 8 of 8
  1. #1 Can a Panasonic 7.9" monitor with with Epic?
    Oct 2008
    Gorham, Maine
    Does anyone know of any combination of settings for an Epic and a Will a Panasonic BT-LH80W monitor that will work?
    Or conversely, does anyone know for sure that there is no setting that will work?
    The specs seem to suggest they will, but I've not been able to make it happen. Any thoughts?
    David Fuller
    AirStream Pictures
    RED ONE #172MX
    EPIC-M #1053
    Digital FX Greg M's Avatar
    not currently compatible w Epic. Ok on Red One
    digitalfx.tv
    The RGBlog- Ramblings about Cameras, VFX, etc.
    Twitter
    Red One #83
    Epic-M #98 and #240
    Epic-X #83 and #116
    Oct 2008
    Gorham, Maine
    Thanks Greg. I thought that was the case, but didn't want to sell it if I was missing something dumb.
    Do you know what the incompatibility is? (Just looking for a clue for next monitor.)
    David Fuller
    AirStream Pictures
    RED ONE #172MX
    EPIC-M #1053
    The 80W only supports 1080 PsF, not 1080p. The Epic does not output PsF.
    the Red One is 720p, which is supported by the 80W. We should be getting 720p soon on the Epic, then you can use the 80W
    digitalfx.tv
    Twitter
    Red One #83
    Epic-M #98 and #240
    Epic-X #83 and #116
    Oct 2008
    Gorham, Maine
    Thanks Greg. FWIW, my initial tests with EEpic's 2.05 build that says it outputs 720p doesn't seem to be working either. May be time to sell the 80W.
    David Fuller
    AirStream Pictures
    RED ONE #172MX
    EPIC-M #1053
    Can anyone tell me if this monitor will be supported? Is 720 enabled yet in the Epic-X?
    yes, works now
    digitalfx.tv
    Twitter
    Red One #83
    Epic-M #98 and #240
    Epic-X #83 and #116
    Quote Originally Posted by Greg M View Post
    yes, works now
    Thanks, I also got it working. User error. Had to restart camera after I changed monitor to 720p. Thanks Greg!
