Thread: Disk Array and LTO Tape support for Mac Pro with limited PCIe slots
Results 1 to 5 of 5
  1. #1 Disk Array and LTO Tape support for Mac Pro with limited PCIe slots
    Senior Member Tim Jones's Avatar
    Dec 2008
    Scottsdale, AZ, USA
    Hi Folks,
    I was asked in a private email about using a single SAS RAID HBA in a Mac Pro to support both a disk array and a LTO-5 tape drive or library.
    Currently, the ATTO R6 family of SAS RAID HBAs is the only viable solution for a single slot. The other raid vendors have focused primarily on disk I/O performance meaning that tape I/O is simply not available, so you can't use Highpoint, Areca, or AOC with tape.
    As to the ATTO, while their R-series HBAs support both disk and tape very well, the largest card for a scenario involving an external disk array and tape is the R680. Because that card has 2, 4 channel ports, you're limited to a 4Bay JBOD chassis or a more expensive unit with a SAS expander so that you can connect more than 4 drives to the 4 channel port. In the lower priced solutions (G-Tech, Sans Digital, etc.), the channels are simply passed through to the drives point-to-point. This means that you can only attach one drive per available channel. If you go with a more expensive external drive chassis that uses a SAS expander (Example Unit), you would use only one of the 4-channel ports to feed the disk array leaving the second available for tape.
    Therefore, if you can live with 4 drives, then the G-Tech and Sans Digital solutions with the R680 are great (I use a Sans Digital on my system). However, if you require higher drive densities, you'll need to go with a SAS Expander-based chassis to support both disk and tape with the R680.
    Tim
    Tim Jones
    brumeister - www.productionbackup.com
    If one would want to use a point to point jbod enclosure like the Areca 4036?
    http://www.areca.com.tw/products/6gsasjbod.htm
    and ZFS,
    would this work with an LTO-5 simultanously?
    http://www.attotech.com/products/pro...=ESAS-H6F0-000
    Thanks!
    Jonas
    Jonas
    Showreels
    Dec 2008
    Scottsdale, AZ, USA
    Quote Originally Posted by Jonas Rejman View Post
    and ZFS,
    Thanks!
    Jonas
    To answer your question, yes - that would work so long as you have two slots - one for the Areca and one for the ATTO. The point of my post was to identify a solution for situations where you only have 1 slot available in your Mac Pro and you need to add a RAID array AND a tape drive / library. In that case, you would not be able to have both the ATTO and the Areca cards installed.
    Tim
    Tim Jones
    Dec 2009
    Montreal
    Don't some LTOs work with USB as external boxes? I think LTO is lower than USB 2 anyway, so no card necessary.
  5. #5 The proof is in the tasting of the pudding ...
    Dec 2008
    Scottsdale, AZ, USA
    Quote Originally Posted by Rob Ruffo View Post
    While were able to get pSCSI LTO-1 drives working with the Ratoc USB - SCSI adapter, most LTO-2 and higher drives fail because the USB to pSCSI adapters are designed for disk I/O - which is generally a burst operation. Tape drives are designed for continuous streams of data and they can cause serious failures in the devices themselves. Basically, the device is designed for a 45% data throughput rate while a modern tape drive will drive them at 90% to 100%. In fact, we've seen interfaces that work fine with disk arrays fail horribly when used to write to VXA, AIT or DLT (let alone high-performance LTO). USB-2 can burst 43MB/sec. This is the equivalent of an LTO-2 drive. LTO-3, 4, and 5 all require much higher levels of throughout, with LTO-5 needing better than 140MB/sec to properly stream non-compressible data.
    We really are stuck here until the Thunderbolt to SAS solutions become available .
    Tim
    Tim Jones
Tags for this Thread
View Tag Cloud
