Differences Between Scarlet, Red One and Epic: Tech Specs Side by Side Chart
EPIC-X and EPIC-M
RED ONE-MX
SCARLET-X
SENSOR
14 MEGAPIXEL MYSTERIUM-X™
14 MEGAPIXEL MYSTERIUM-X™ |
| PIXEL ARRAY |
5120 (h) x 2700 (v) |
| S/N RATIO |
66db |
66db |
| DYNAMIC RANGE |
13.5 stops, up to 18 stops with HDRx™ |
13+ stops |
13.5 stops, up to 18 stops with HDRx™ 6 fps with 5K FF and HDRx On 12 fps with 4K HD and HDRx™ On |
| MAX IMAGE AREA |
4480 (h) x 2304 (v) |
| LENS COVERAGE |
27.7mm (h) x 14.6mm (v) x 31.4 mm (d) |
24.2mm (h) x 12.5mm (v) x 27.3 mm (d) |
27.7mm (h) x 14.6mm (v) = 31.4 mm (d) |
| LENS MOUNT |
PL (Canon mount opcional) |
PL (Nikon mount opcional) |
Al Canon EF (PL mount optional) |
| DEPTH OF FIELD |
Equivalent to S35mm (Motion) / APS-H (Still) lenses
Equivalent to 16mm (Motion) lens in 2K RAW |
Equivalent to S35mm (Motion) lens
Equivalent to S35mm (Motion) / APS-H (Still) lenses |
| ACQUISITION FORMATS |
5K RAW (Full Frame, 2:1, 2.4:1 and Anamorphic 2:1)
4.5K RAW (2.4:1)
4K RAW (16:9, HD, 2:1 and Anamorphic 2:1)
3K RAW (16:9, 2:1 and Anamorphic 2:1)
2K RAW (16:9, 2:1 and Anamorphic 2:1)
1080p RGB (16:9)
720p RGB (16:9) |
4.5K RAW (2.4:1)
4K RAW (16:9, HD, 2:1, and Anamorphic 2:1)
3K RAW (16:9, 2:1, and Anamorphic 2:1)
2K RAW (16:9, 2:1, and Anamorphic 2:1) |
5K FF REDCODE RAW (Full Frame)
4K HD REDCODE RAW
3K HD REDCODE RAW
1080p REDCODE RAW
1K REDCODE RAW |
| PROJECT FRAME RATES |
23.98, 24, 25, 29.97, 47.96, 48, 50, 59.94 fps, all resolutions |
23.98, 24, 25, 29.97 fps @ 4.5K, 4K
plus 50, 59.94fps @ 3K, 2K |
23.98, 24, 25, 29.97, 47.96, 48, 50, 59.97 |
| DELIVERY FORMATS* |
4K : DPX, TIFF, OpenEXR (RED RAY via optional encoder)
2K : DPX, TIFF, OpenEXR (RED RAY via optional encoder)
1080p RGB or 4:2:2, 720p 4:2:2 : Quicktime, JPEG
Avid AAF, MXF. 1080p 4.2.0, 720p 4:2:0 : H.264, .MP4 |
| PROGRAM OUTPUT |
HD-SDI Clean Feed
2K RGB, 1080p RGB or 4:2:2, 720p 4:2:2
SMPTE Timecode, HANC Metadata, 24-bit 48Khz Audio |
| MONITOR OUTPUT |
HD-SDI and HDMI with Frame Guides and Look Around
2K RGB, 1080p RGB or 4:2:2, 720p RGB or 4:2:2
720p RGB or 4:2:2
HD-SDI and HDMI with Frame Guides and Look Around or Clean Feed 1080p 4:2:2, 720p 4:2:2 SMPTE Timecode, HANC Metadata, 24-bit 48Khz Audio |
| DIGITAL MEDIA |
REDMAG (SSD) Module : (64, 128, 256GB Media) |
REDFLASH (CF) Module : (16GB Media)
RED SSD™ (64GB, 128GB, 256GB Capacity) |
| REDCODE™ |
12 and 16-bit RAW : Compression choices of 18:1 to 3:1
1-120 fps 5K, 4.5K
1-150 fps 4K
1-200 fps 3K
1-300 fps 2K |
12-bit RAW : RC28, 36, 42 Quality Levels
1-30 fps 4.5K, 4K
1-60 fps 3K
1-120 fps 2K |
16-bit RAW Processing : Compression choices of 18:1 to 3:1
1-12 fps 5K FF
1-30 fps 4K HD
1-48 fps 3K HD
1-60 fps 1080p HD
1-120 fps 1K |
| AUDIO |
2 channel, uncompressed, 24 bit, 48KHz.
Optional 4 channel, and AES / EBU digital audio. |
4 channel, uncompressed, 24 bit, 48KHz. |
| MONITORING OPTIONS |
RED LCD 5" Touchscreen Display
BOMB EVF™ High Definition Viewfinder |
RED LCD 5" Flat Panel Display
RED PRO LCD 7" Flat Panel Display
| REMOTE CONTROL |
Wireless, Ethernet, RS232, GPI Trigger |
USB-2, GPI Trigger |
REDLINK Wireless, Ethernet, RS232, GPI Trigger |
| WEIGHT |
5lbs. Body only |
10lbs. Body |
5lbs. Body only |
| CONSTRUCTION |
Aluminum Alloy |
Aluminum Alloy |
Aluminum Alloy |
| COLOR |
Black |
Black |
Battleship Gray Brain Body, Black Canon Mount and Side SSD, All DSMC Modules Black |
| TEMPERATURE RANGES |
Operating Range: 0˚C to +40˚C (32˚F to 104˚F)
Storage Range: -20˚C to +50˚C (-4˚F to 122˚F) |
| * FROM REDCINE-X |
