Thread: Why is RedCine-X Pro not using the DeckLink to output the signal?
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1 Why is RedCine-X Pro not using the DeckLink to output the signal?
    Senior Member Luis Otero's Avatar
    Orlando, FL
    By reading and posting in other thread, I was compelled to open this new thread. The issue is, basically, why all other software that use the Rocket to perform the debayering (such as Resolve) can funnel the signal via the DecLink, and RedCine-X Pro needs to use the Rocket outputs? In my case, my monitor has two HD-SDI inputs, so I do not have to be connecting/disconnecting cables.
    So, my question or request to BMD and/or Red is: can the Rocket signal from RedCine-X Pro be funneled, somehow, through the DeckLink so a single output can be used? Again, if a hosting program like Resolve, which uses the Rocket for the debayering, how is this signal sent, and previewed in real-time, via the DecLink, but not for RedCine-X Pro? I mean, this cannot be happening by pure black magic.... Can someone from Red explain the reason in basic English? I do not recall seeing any previous discussion and explanation about this particularity before.
    Thanks,
    Luis Otero
    Epic-X #1616
    (Old Red One 711)
    I was scammed, and I love it...!
    Digital Emulsion
    Orlando, FL
    IMDB: www.imdb.com/name/nm3889059/
    Senior Member Matt Ryan's Avatar
    May 2008
    Long Beach, CA.
    Quote Originally Posted by Luis Otero View Post
    Thanks,
    In Resolve, the Rocket is only used for rendering output along with the CPU. Your GPU is used for playback and grading and does not use the Rocket.
    Orlando, FL
    Quote Originally Posted by Matt Ryan View Post
    Yes, that is understood. The question is if the signal can be routed, as Premiere Pro, Final Cut, After Effect, etc. do, via the DeckLink. They just need to manipulate their signal path, build a simple, effective GUI to select what is the signal path for monitoring desired, and the image shows via the DeckLink. I do not see this anyway different: RedRocker debayers, RedCine-X, as it has today, provides a GUI where the signal path is selected (HD-SDI or DVI), and we can see it projected. The only modification would be to add DeckLink to the list of signal paths, along with the built-in HD-SDI or DVI.
    Luis Otero
    Epic-X #1616
    (Old Red One 711)
    Digital Emulsion
    Orlando, FL
    May 2008
    Long Beach, CA.
    i see what you mean now. Yes you are correct, seems like RED could do this in a simple update. It doesnt seem like it would be that difficult to make it happen.
    Orlando, FL
    Of course, we have not talk about other possible reasons, such as "territory protection", and other business rationales that will justify future business developments and paths. I am almost certain that it is possible NOW to do such signal re-routing.
    But might have not happened since it could create a habit and complacency of watching images in 2K, or the opposite, which is a lack of desire to watch images in Quad-HD. Let's not forget about the Break-out box, RedRay, 4K RedLaser Projector, and who knows what else... I mean, this is just thinking outloud.
    Luis Otero
    Epic-X #1616
    (Old Red One 711)
    Digital Emulsion
    Orlando, FL
    May 2008
    Long Beach, CA.
    it would be cool if you could output the full res 4k from the Rocket in redcine-x pro through the blackmagic decklink 4k card. (That is once 4k displays or projects are in a decent price range.)
    When Blackmagic released that card I thought maybe RED influenced them in doing it for a specific reason, I guess not.
    Orlando, FL
    Well, that will also be possible now, I think, since the DeckLink has dual HD-SDI, as the Rocket does.
    Luis Otero
    Epic-X #1616
    (Old Red One 711)
    Digital Emulsion
    Orlando, FL
    Jan 2008
    Obviously there are complications I imagine making this happen from the card's output from REDCINE-X PRO. The card debayers, then sends video signals straight out, or renders out to files, and updates the GPU. I imagine what's coming off the cards HD-SDI is significantly different from what you see on your computer display (as in it probably has embedded timecode, and all manner of other video related data, where as the data getting sent back to update the GUI from the card is different again. I imagine his is done in hardware and the cards design doesn't make it intrinsically easy to feedback to a second output card from with REDCINE-X PRO otherwise they would have done it already.)
    In the meantime, why don't you spend not all that much money and make yourself a patch panel to swap your connections around. It would be a pretty basic patch to set up compared to moving around cables everytime.
    Orlando, FL
    Craig,
    As I stated before, my monitor has two HD-SDI inputs, so I just use a finger to select between Input 1 or 2. However, not everyone has such benefit.
    Luis Otero
    Epic-X #1616
    (Old Red One 711)
    Digital Emulsion
    Orlando, FL
    Senior Member jake blackstone's Avatar
    Nov 2007
    Technically, Decklink doesn't have dual SDI outputs. It's 4:2:2 and 0:2:2 outputs for 4:4:4 derived output.
