Click here to go to the first RED TEAM post in this thread.   Thread: 4K HD and 4K 16:9 difference
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
  1.   This is the last RED TEAM post in this thread.   #11
    Red Team Stuart English's Avatar
    Irvine, Ca
    Quote Originally Posted by Chris McKechnie View Post
    So if you're wanting to acquire in 5k but have a 1080p deliverable, what would be the ideal aspect ratio to not lose too much of what you're seeing on the monitor when recording?
    Personally like 5K WS as that is 5120 x 2160 pixels which means I can crop to 3840 x 2160 for Quad HD or crop to 3840 x 2160 and scale 2:1 for 1080p HD, or scale 5:4 for 4096 x 1728 (DCI Scope) or crop to 4096 x 2160 or 3996 x 2160 (DCI Flat) and still have some room to reframe for 3D...and I can still record as high as 120 fps ...
    Workflow Wizard
    Seems people missed the OP's exact question. 4K 16:9 is *NOT* 4096x2160, it's actually 4096x2304 and is a 16:9 aspect ratio.
    RED One "4K" modes are as follows:
    4.5K = 4480x1920 | 2.33:1
    4K 16:9 = 4096x2304 | 16:9
    4KHD = 3840x2160 | 16:9 (this is commonly known as quad-HD or 4xHD 1080p)
    4K2:1 = 4096x2048 | 2:1
    The differences between 4K 16:9 and 4KHD are that the 4K 16:9 frame is actually "4K" in that it's 4096 pixels across. Being slightly larger, it is closer in size to the full Super35 frame, but not by much -- it's very close to 35mm Academy format. The 4KHD mode has some advantages as it provides quicker scaling to 1080p HD since it is even 2X scale in both linear directions or a total of 4 times the number of pixels.
    - Jeff Kilgroe
    Senior Member Tim Whitcomb's Avatar
    Jan 2009
    Portland, OR
    Quote Originally Posted by Stuart English View Post
    +1 5K WS seems to provide the most delivery options for the buck and the simplest 5K workflow.
    for 1080P delivery... it should also be noted that 4K HD transcodes much faster than 4K 16:9 - because the math is perfect - no rounding. either and faster with our without Red Rocket
    Kind regards,
    Tim Whitcomb
    Filmmaker
    Dec 2009
    Montreal
    Quote Originally Posted by Uli Plank View Post
    I suppose they dropped it for other sizes since for a delivery in HD 1080 it doesn't make much sense to use anything else but Quad HD.
    You might say that you'd like 5K 16:9 for getting a bit wider from the same lens, but that's about all I can see as useful. In most other cases you'd shoot for multiple delivery formats anyway and would need to frame accordingly. BTW, 5K is great for re-framing in post, but then your original ratio doesn't matter that much.
    It does make sense - it gives you a field of view that is much closer to standard academy.
    Dec 2009
    Montreal
    Quote Originally Posted by Bob Gruen View Post
    Think of what happens to individual pixels when you scale down. In 4K HD a four pixel square is combined into one final pixel. This is not true of the other formats: when combining the 'edge' pixels have to be handled in terms of percentages. Think of 3K HD where 1.5 pixels in each direction get combined into one pixel. 5K HD is much more complex.
    If final delivery is 1080p I think I'd shoot 4K HD, unless I needed a wider shot than my widest lens could deliver.
    Bob
    This is terrible advice.
    Senior Member Steve Sherrick's Avatar
    Boston
    Quote Originally Posted by Rob Ruffo View Post
    Which part are you saying is terrible advice?
    Steve Sherrick
    Chief Collaborator
    Modern Vintage Media
    STEVESHERRICK.COM
    Local 600 DIT/Operator
    Dec 2009
    Montreal
    Quote Originally Posted by Steve Sherrick View Post
    It is advice that is from the Brute Force Academy of Cinematography.
    A wider field of view will look different if filmed by a 35mm lens at 5K than it will from a 24 mm lens at 4K. Not just sharper, but different focus falloff, not to mention signal to noise on final image is much higher at 5K - you are using more light to create your image. AT 4K you are zooming in on noise, however nominal that noise may be on MX. Also, side-by-side, even on Red One, 4K 16:9 looks creamier and less digital than 4KHD.
    This kind of simplistic, vaguely brutalist advice bugs me - it's like when people say "just adjust your iris if you want less light".
    There is more to all this than counting pixels...
    Senior Member Andrae Palmer's Avatar
    Aug 2007
    Fort Lauderdale, FL
    Thank you Jeff! A buddy of mine needed to know what aspect ratio matched 4096 x 2160 on the RED One... your post gave me the closest aspect ratio.
    Andrae Palmer
    Founder, FACETMEDIA LLC
    facebook.com/facetmedia
    Package for rent in South Florida with EPIC-X Camera #721 & RED One #6353, RPP, RED Rocket, RED 18-50 & Oconnor 2575C. Davinci Resolve, FSI LM-2461W & Mac Pro 12 core. Rentals/Equipment List: http://facetmedia.com/red-rental/
    San Diego, CA
    Seriously though, if there's no realistic route to a piece being seen theatrically, then it will live its life as a piece of 1080P rec709 media (at best) destined for compression to less than 8mb/s in MPEG-2. For that pathway I think the slightly crunchier edges in the "brute force" full integer downscale might actually provide more usable metrics for the encoder's algorithms. If so, that would typically (some high contrast or extreme exposure samples excepted) improve the IQ of the encoded media the viewer will see.
    On the flip side, for any narrative or "glossy" piece that lends itself to a creamier look I'd shoot the biggest frame I can (love that 5,120 by 2,700 on the Epic) with a 16x9 guide for reference and manage the scaling filter type, contrast distribution, saturation, curves and other values during grading to reveal as much or as little of the true resolution of the base image as suits creative intent/cosmetic imperatives/etc.
    Cheers - #19
    Jan 2008
    Charlotte, NC
    Simplistic? I believe I stated exactly why 4KHD came to be, it's benefits, and pointed out that I could also get that little bit of extra width if I were up against a wall and needed it.
    Brutalist? Are you serious? What planet are you from where switching between 4K 16:9 to 4KHD is some kind of violent behavior?
    I hardly think that a few wide 4K shots are going to jump out of a film that is otherwise 4KHD. As someone who is focused on the entire production process (pre-prod, prod, and post) I stand by my advice. Not everyone has a RedRocket card and all the wonderful support hardware in their workstation, and there is a significant difference between the two when editing and rendering.
    There are reasons that Red created the 4KHD format. One is the math gets easier for the computer and oh, BTW: it's more accurate too. Scaleing in any other fashion creates "creamyness" or as others would call it "softness" due to pixels being unevenly divided and added to each other.. If you want softness you can add it in post easy enough (oh dear!). I have yet to see a sharpening algorithm that actually worked.
    Hey Rob, I actually have 4K 2:1, 3K 2:1 and (horrors!) 2K 2:1 in the same film!!! I had to because I needed slow motion... Had to do it. Guess it's not worth watching... Too brutal...
    Sheesh...
    Bob
