Thread: Something new for adding filters to the Nikon 14-24
Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1 Something new for adding filters to the Nikon 14-24
    Mar 2011
    Toronto, ON Canada
    ___________________________
    10 frame handles
    Vimeo
    Scarlet #329 "HAL"
    Cool, i'm gonna buy one.
    And does anyone know a Mattebox solution(french flags) for this lens?
    I know 3 filter solutions (Lee,Lucroit and this new Fotodiox) but i would need 3 flags to avoid the huge flare that this nikkor has.
    Senior Member Bill Sepaniak's Avatar
    Dec 2011
    Long Beach, CA
    I just ordered a Vocas 325. It should be in this week. I will let you re any fit/flare/vignette issues. However, I think I will pick up the new Fotodiox as well.
    Many thanks!
    Mar 2011
    Toronto, ON Canada
    I don't believe the 14-24 will work with any mattebox without vignetting.
    Quote Originally Posted by Bill Sepaniak View Post
    10 frame handles
    Vimeo
    Scarlet #329 "HAL"
    Sweden
    Good find!
    Thank you
    Quote Originally Posted by Bob Gundu View Post
    Maybe zooming the lens to 16-18mm range would be the solution?
    Dec 2011
    Long Beach, CA
    From Steve Gibby (but using a Ruby modified 14-24):
    "We found that at 14mm the Ruby 14-24 shows a small amount of the Red matte box on the right and left edges. I simply pushed in to half way between 15mm and 16mm and the easily lost the matte box edges. The 14-24 is a full frame 35mm lens. Images from the lens are very crisp, good contrast, and clean. I expected that because I've used the stock Nikon 14-24 on Red One with excellent results."
    And from from Jacek Zakowicz, at OptiTek:
    "I checked the 14-24 for vignetting with filters:
    It will work with Red sensor (current one) when you use 4x5 filters(ARRI LMB5 clip on?)
    6x6 filters will provide full frame(24x36mm) coverage (LMB3?)
    The filters were right up against the front of the lens- I haven't checked for stacking more than one.
    The front of the lens is 96mm diameter so you'll need:
    1. 96mm adapter plate for the mattebox (?)
    2. or a bellows that steps down to 96mm for swing away
    3. step down split ring to 96mm for a clip on."
    I am still going to try it-w-the Vocas, but I need to get some "nuns nickers" and I will let you know how it goes. Even if I have to push to 15 or 16mm, I'll be happy with that.
    I wish you a good luck with it, i hope to hear good news about you soon
    What does Ruby modified 14-24 mean?
