Click here to go to the first RED TEAM post in this thread.   Thread: POSTED: SCARLET-X Firmware v2.0.8 (BETA)
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1.   Click here to go to the next RED TEAM post in this thread.
  #1 POSTED: SCARLET-X Firmware v2.0.8 (BETA)
    Posted on RED.com - SCARLET-X Firmware Beta Build v2.0.8. These are password-protected downloads. Beta Build v2.0.8 is for testing and preview purposes only.
    Read all instructions contained in the download files before proceeding with download. Also, please review the operations manual.
    NOTE: Firmware v2.0.7 and up are required to use the PRO BATTERY MODULE (QUAD).
    If you have any other questions or feedback, please contact Technical Support.
    Thanks, BC
    Senior Member Brian Iannone's Avatar
    Sep 2011
    Los Angeles & France
    Thanks Brent. :-)
    A 19-year-old student with a love for cinematography and a passion for geophysics.
    Personal: www.brianiannone.com, Portfolio: visuals.brianiannone.com, Business: www.ik3.co, Twitter: @brianiannone
    The List of Scarlet Names | The List of EPIC Names
    Senior Member Jon Carr's Avatar
    Aug 2009
    NYC
    Any major changes to this build?
    Dp Reel
    http://www.visualcinema.com/reels/
    Rentals in NYC
    http://www.visualcinema.com/rentals/cameras/
    EPIC-X #5359 GNX (soon to be Dragon)
    Canon & PL mount, Canon 16-35, 24-70, 70-200, Rokinon 24mm, 35mm, 85mm, & everything you need to shoot RED!
    It's REDcode or no code...
    Thanks Brent and Red programmers. I just installed the OLPF Port Bushing and stepped out for a bit. Darn. I'll have to wait until later to install.
    phfx.com IMDB
    Scarlet-X #316 "Skully"
    Mar 2011
    Toronto, ON Canada
    Significant changes since previous build 2 v2.0.5:
    Support Rear Battery module
    Support max REDcode using 256GB mag (same as 64/128GB Mag)
    Support Canon Extender
    Support Focus Distance value in R3D file
    Fix to correct zebra 2 Hi IRE settings and set default to 47
    Fix for camera not booting with HDRx enabled
    Fix to populate “Channel Map” and record audio data only with valid source
    Fix to display proper false color ICON on REDmote upon connection
    Fix to reset lens parameters and snapshot to 0 when lens disconnects.
    Fix for invalid Canon config files
    Fix for 300mm 4L lens focal length issue
    Fixes for manual Lens Movement Detection/Correction
    Fixes for touch track and continuous modes
    Enhancements to lens movement correction
    Enhancements to AF window placement on switch to magnify mode
    Audio Input UI changed to single checkbox control (Audio Record Enable)
    Operational notes specific to Build 2 v2.0.8:
    EVF not supported in playback
    Phantom power disabled
    Sensor Flip disabled
    5K ANA clips not supported in playback
    Detaching monitor during playback will require reboot on monitor re-attach
    Zoom Rocker mapping to aperture is not fully implemented
    Camera powered RED BRICK may display voltage instead of battery capacity on some cameras.
    EVF black level raised in some cases
    ISO setting limited to min of 250
    Image Magnify is available during preview, but not during recording.
    HD-SDI is True Progressive, and do not support 1080i or 1080 PsF signal formats.
    ___________________________
    10 frame handles
    Vimeo
    Scarlet #329 "HAL"
    Senior Member Les Dittert's Avatar
    Sep 2011
    Does "Fix for invalid Canon config files" explain why only manual and confirm are enabled on my Tamron17-50 and Sigma8-16 lens's ?
    No more auto focus.
    Both of these worked before.
    Edit: it does work now that I try again ( after re-setting up gig-e master-slave ) . Display shows focal length and focus distance now. So far so good!
    Thanks Brent!
    Downloading now.
    Is there a way to save changes in the Media playback yet? I think I could be halfway done with a rough cut if that were possible. That and a clip delete function would be awesome! Many thanks to you guys at RED. Keep trucking, this camera is becoming more and more amazing!
    Firmware Upgrade complete. No immediate concerns, but I'll test it out more tomorrow.
    phfx.com IMDB
    Senior Member PatrickFaith's Avatar
    Nov 2011
    Northern California
    Thanks Phil for checking this out ... for me ... i'm just going to wait till this goes production and you guys burn it in.
    I'm using 24 fps QHD mode, and external recorder for audio for everything i do ... so I don't think this effects me.
    I would like the touch screen to work a bit more "nicer" but couldn't decipher what this means:
    On the other hand, I was thinking of playing around with hdrx ... and with:
    Not going touch HDRX until 2.0.8 goes production
    I am finding these beta notices very good to read, even as I'm going not going to use them ... so I know what not to mess around with.
    This camera does so much, that really I'm finding that in 24 fps at 1/24 time in QHD ... the camera is a total dream and extremely stable, and does everything I need.
    I'm still testing with timecode jamming and stuff ... but so far everyone of my "problems" have been operator error.
    http://www.youtube.com/patrickfaithart & http://Pudl.tv
    "Litl" #250 "Pudl" #397 of "Ink" (Monochrome) #3752
    Senior Member Ryan Hamblin's Avatar
    May 2008
    Nashville TN
    Phil does this firmware have the red gamma 3 setting?
    Ryan Hamblin | Director
    Represented by:
    TAILLIGHT
    reel: http://www.taillight.tv/ryan.html
    BrainStemDigital production|post|vfx
    www.brainstem.tv
    follow us on twitter: http://www.twitter.com/brainstemdigit
    Gear list: RED Scarlet-X #00235 (PL & Al Canon), Rokinon 8mm F/3.5, Rokinon 14mm T/3.1, Rokinon 24mm, 35mm, 85mm T/1.5, Tamron 70-200 f/2.8, various ND and filtration
