Click here to go to the first RED TEAM post in this thread.   Thread: Is R3D 4:4:4 or 4:2:2?
Page 4 of 25 FirstFirst 1234567814 ... LastLast
Results 31 to 40 of 245
  1.   Click here to go to the next RED TEAM post in this thread.
  #31
    The OLPF filters all in-coming light, not just luma. Although the level of filtering applied is to balance sharpness and propensity for aliasing on the luma, it also filters the chroma, albeit not to the same extent as the luma. There is the possibility of chroma aliasing, albeit at a lower level than most cameras would allow for aliasing in general, and also, remembering as you point out that chroma moire is reasonably easily filtered if it ever appears.
    Graeme
    www.red.com - 5k Digital Cinema Camera
    Science enables stories. Stories drive science
    FLUT™, Image Processing, Colour Science and Demosaic Algorithms, REDRAY 4K delivery
    Senior Member Jack Shanahan's Avatar
    Nov 2011
    NYC
    Quote Originally Posted by Graeme Nattress View Post
    Sensor colour gamuts are not precisely defined in the way that monitors are with their distinct primaries. Our cameras all have similarly wide gamuts, and all colour filter array cameras pretty much use the same dyes on the sensor anyway.
    Where we continually try to work, improve and learn is raw development, with a strong sense of digital cinema aesthetic rather than a video aesthetic in mind. In the process of working on REDColor3 I've learned a significant number of new nuances which will influence future development.
    Graeme
    and this is why i bought RED.
    Jack Shanahan
    www.jackshanahan.com
    EPIC-X + Zeiss ZF Duclos Mods
    Senior Member Stivan Widick's Avatar
    The Most-Chosen City on Earth
    I'd pay to go to Graeme lectures. Good stuff.
    Epic-X #01895 (23) "Jughead"
    Senior Member Les Dittert's Avatar
    Sep 2011
    Graeme
    Hi Graeme,
    Sounds like there might be a chance of some RCX debayer improvements in the near future, then ? Great !
    I will soon ( possibly today ) be posting a RAW Cineform mov that will demonstrate how the Red output looks when run through that workflow. They have several methods available for debayer, switchable on the fly in firstlight.
    Just an extra data point for people to see and compare!
    -Les Dittert
    Banned
    May 2007
    Quote Originally Posted by Miltos Pilalitos View Post
    I think you didn't pay attention to what Graeme said. Your statement doesn't compute.
    I did pay attention, and it computes perfectly. I also design debayering algorithms in my spare time.. its a nonsense question, but is bayer sub-sampled colour = yes.
    4:4:4 implies no colour subsampling
    Yes, debayering algorithms have improved, they do a good job of guessing at missing data.. but tell someone deciphering/analysing the dead sea scrolls pixel by pixel that working from a debayered "guesstimate", compared to a 4:4:4 aligned scan, is a good thing .. but i say this tongue in cheek to make a point
    its was a fun/geeky question, with no correct answer .. but ill still take mine in this particular case
  6.   Click here to go to the next RED TEAM post in this thread.
  #36
    "4:4:4 implies no colour subsampling " indeed it does, but it implies that no chroma sub-sampling occurs in a Y'CbCr space as a means of compression.
    "bayer sub-sampled colour = yes" indeed, but at a completely different part of the chain in a different colour space and different linearity by a different method.
    Graeme
    Banned
    May 2007
    Graeme
    it doesn't really matter if the sub-sampling happens after a lossy conversion to yuv, for compression reasons, or whether it happens because it a bayer pattern made up of impure colour samples, since the chroma in yuv consists of R/B differences relative to green.. its similar to how many debayering algorithm work.. such as smooth hue interpolation, or any debayer that uses the green channel to guide reconstruction of the missing red and blue samples..
    i agree about the colour space stuff being different etc, and that most yuv conversions are very lossy if reversed back to rgb.. and redcode doesn't do that..
    So, ill try a compromise..
    4:4:4 AND 4:2:2 both = reduced resolution colour (relative to luma), made worse by lossy colour space transformations which reduce R,G,B information uniformly, but leaves data that is easier to compress and transmit
    RAW = similar reduced colour resolution (ratio), but not subjected to low quality realtime in-camera yuv colour space transformations= less wasteful = nothing baked in = 1/3 datarate = future proofed data (should you or someone else improve algorithms) ..
    its still colour subsampled, I believe that is mentioned in the original Kodak paperwork by mr Bayer ;)
    Debayering is only half redcode success, the wavelet transformation of course, and the way it distributes quantization across the frequency range and then weaves it back together is the other big part of the equation, and the reason you have decent raw image to debayer at all,,
    .. I'm new to wavelets, although I'd been using Haar functions in audio processing without realizing what I was doing.. I'm currently working on an image frequency "equalizer" ..6 band..getting there..you should have a play with wavelets if you haven't already.. you seem to have nailed debayering
  #38
    "it doesn't really matter if the sub-sampling happens..." well, yes it does because the visual result is rather different. With chroma decimation after a YCbCr transform, chroma resolution is some fixed ratio of whatever it was before it was sub-sampled. In the Bayer pattern sensor system, measured chroma resolution will be different for each colour, depending upon many factors.
    Graeme
    Banned
    May 2007
    Graeme
    I already described some of the differences above, and why the results can be different, and in greater detail than your above post. If you throw colour information away, its subsampled. If the colour samples are reduced in resolution to start with, they're also sub-sampled
    When some one asks me if is something 4:4:4 or 4:2:2, I don't assume they're comparing video standards with D.I, and the original post wasn't IMO, what they're really asking is "is the colour/chroma/whatever" subsampled. Answer, yes .
    Debayering is intelligent/subjective interpolation, and bayer patterns are a form of colour sub-sampling, as are the 4:4:4 and 4:2:2 video formats
    I don't think anybody will read my answers and say "so redcode is 4:2:2, or 4:4:4", because it is neither or either, depending on post decisions, formats , resolutions.. but the sensor is biased towards luma, not colour.. that is a common design. I'm not afraid to discuss differences and similarities between formats
    most compression systems use prediction to encode differences, with redcode its wavelet coefficients spread across frequency/resolution bands, with traditional macro block based DCT encoding its largely the difference between G and R/B (through a conversion to YUV) and heavy blocky quantization, or temporal compression with mpeg2.. so yes, there are differences, as I already said, the biggest being the wavelet transforms instead of DCT etc IMO, ..or the fact that raw files aren't limited to in-camera circuitry with cost/ speed restrictions
    ..but since 4:4:4 and 4:2:2 video tends to end at 1080p 10bit, and redcode can record 5k at 12bit.. i think you should be less touchy and not restrict your answers to redcentric ones.. most people who haven't compared camera formats won't be buying Scarlets , Epics or R1s.. those that have can probably handle understanding the differences, and similarities, between signal encoding systems
    A balanced discussion requires both sides of an argument, and while I disagree with little that you say, sometimes when you respond to posts you seem to take a line that is b&w and designed not to confuse people (well your busy i guess..), which is understandable, but at the expense of some accuracy.. which results in a shorter discussion and then the "magic pixies" appear
    with a few of my past posts, and this one, i feel you're trying to counter me with my own arguments repackaged.. pushing against an open door
    "measured chroma resolution will be different for each colour, depending upon many factors." .. well yeah, but is this a master class in stating the obvious? ..if I interpolate adjacent pixels from a 4:4:4 video source and blend that with the original colour will I not get a different colour, for each pixel?.. probably! Will it depend on many factors? .. if I make it adaptive, sure.. but explains nothing
    Bayer pattern is a bandwidth reducing / colour sub-sampling design, I acknowledge many differences, but that is something it has in common with other colour video acquisition systems, including the 4:4:4 and 4:2:2 video standards. Why not start with that, then EXPLAIN the differences between that and redcode (without giving away what type of elves you use)
    Sensor readout (RGB bayer pattern) -> camera colour sytem/realtime-debayer -> monitor
    Wavelet Transformation
    Compression
    Write to Media
    backup/verify ->post: inverse wavelet transformation/DSP/Colour conversions/HQ debayering etc -> 4:4:4 or 4:2:2 or DPX etc
    why not explain how basic debayering interpolations can work, show examples of how adaptive interpolation can, statistically speaking, increase resolution beyond simple linear interpolation.. then people who are interested might gain actual understanding of the processes at play
    The Alexa can record raw and non-raw .. the non-raw looks as good as it does, in part, becasue of the downsample from the spatially over-sampled bayer .. and the split signal gains for retaining low and high lights.. and maybe the log colour format.. all systems are complex , lets learn about them
  10.   Click here to go to the next RED TEAM post in this thread.
  #40
    My main issue here is correct use of terminology, because there's been some serious abuses of this terminology in the past from people who should know better.
    Graeme
Tags for this Thread
View Tag Cloud
