Thread: Quick solution to keep power adaptor from too easily disconnecting
Results 1 to 4 of 4
  1. #1 Quick solution to keep power adaptor from too easily disconnecting
    Oct 2010
    DC & OC
    Just wanted to share a quick solution in hopes it can keep it happening to you while you are filming.
    While shooting via power adaptor, I accidentally kicked the power adaptor and it barely came lose; which abruptly turned off my Scarlet, so I wired up the adaptor to keep it from even coming lose a bit. A little wire wrapped around the top and bottom to keep it secure.
    Scarlet #518 "Bottle Rocket"
    FyreworxFilms.com
    Senior Member Solomon Nero's Avatar
    Oct 2010
    NY
    good to know!!! Thanks for the tip!
    I usually tape it up with a strip of 1" white camera tape for the same reason!
    Director/Digital Camera Operator/2nd AC/DIT/Data Manager
    London, UK.
    Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.
    Senior Member Nathaniel Kramer's Avatar
    Dec 2011
    New York City
    I too have pulled the cord out of the adapter with my feet -The AC power adapter and cable is the only badly designed component for the Epic.. I would like to see the adapter farther down the power cord so there is no bulky brick shaped object near my feet. If im on sticks, I gaff it to one of the legs, but there must be a cleaner option. But the contrary is that its sort of a breakaway to protect the camera if someone trips over it..
Tags for this Thread
View Tag Cloud
