Thread: BBC Natural History Unit using Epics
Page 4 of 4 FirstFirst 1234
Results 31 to 40 of 40
  1. #31
    Additional: I have been shooting a lot of high speed material - something wonderful that I've been missing since I gave up my Super 16mm camera for video.
    As a result I have been experimenting a lot with shutter speeds and agree with Kennan on this. But until I get back and examine my material on a larger HD monitors I can't really advise on this matter. But I should have a wide range of experiences to share when I return that I am hoping will be useful.
    Member Alberto Saiz's Avatar
    Aug 2008
    Spain/Kenya/Worldwide
    I have heard BBC´s producer Chadden Hunter say that they`re going to use the Epic in the next series "Wild Arabia" currently in production, so Im sure we will enjoy amazing footage as usual from the BBC NHU shot on RED...
    Alberto Saiz
    www.naturahd.com
    Nov 2007
    Four accessory kits just left my desk for them ...
    Mitch Gross
    Applications Specialist
    AbelCine
    mitch@abelcine.com
    212-462-0100
    Quote Originally Posted by Mark Deeble View Post
    Steve, we've been using Epics since September in Africa for wildlife - using everything from 500mm Nikon primes down to 10x macro. The camera is great!
    Agreed, its a great camera in our business, used it the other week. Still not 100% sure about the 2k for super slow motion - but then its not a Phantom and was never inteded to be.
    Great to see you on the forum Mark, Tides of Kira Wira is my fave wildlife film of all time!
    Steve
    Banned
    Oct 2007
    Tasmania
    Quote Originally Posted by Dave Blackham View Post
    Im not sure what was said ! However there were some positive points on the convertors and the tests we did but also some negative points mostly about sensor sensor coverage. You also need more than one convertor to meet most needs so its not ideal by any means. As I said it will be interesting to see how it all works out. Our own approach has been selecting the best Leica glass we can find that covers the wide end of things, we also have some beautiful Leica Telephoto lenses. Trouble can be expected over 500mm with vibration and it seems more apparent with the higher resolution. Its finding suitable Zooms for wildlife which is our current quest. Mostly our tests were done at 4k and 3k, though some high speed at 2k.
    I agree about Leica. I use Leica Apo Telyt-R converted to PL: 280mm, 400mm and 560mm and Master Primes for wider angles. Heavy and sharp glass. Stunning results. In fact I find the Leicas slightly sharper and more contrasty than the Masters, but much more prone to flare.
    Good to hear that BBC has found out about RED. They usually adopt new technology a couple of years after everyone else does.
    Do you know how much 3D Natural History they are intending to produce versus 2D?
    Senior Member Johnny Friday's Avatar
    Feb 2007
    La Paz, Baja Ca. Sur, Mexico
    BBC has been in production a while now with Wild Africa 3d. (i believe that's the working title)....they have a bunch of crews out all over the contient and a few shooting underwater as well.
    John Friday
    La Paz, B.C.S., Mexico
    www.bajaproductions.com
    EPIC M & 2X for 3d & Deep Epic Underwater Housing
    RED MX with SSD & Underwater Housing
    Oct 2007
    Quote Originally Posted by Pawel Achtel View Post
    So far as we know only for commercial productions via BBC Earth for wildlife, the BBC doesn't have a 3D channel of its own so I think only used in Co Prods. I don't think 3D is expected to be a big format for them for them in the short term. There are some sports shows for test I hear in other areas.
    Dec 2009
    Montreal
    Quote Originally Posted by Kennan Ward View Post
    Steve,
    This is good news as they have really been Varicam prefered!
    Epic, for me gives me the action I could never filmed before! It took four years of Red One to learn the possibilities!
    I am using the older Red one EVF for long lens work, but I also like the B-omb and the enlarge feature using the key set.
    I prefer the 5K, 96fps or the 4K 120fps, slowed down in post (sharpness in 4K / 5K is best) so that we also have post zoom cut aways and slowed down in post. Editing is now the new art form and most people don't get that!
    Tell them, experience still counts for somethings!
    Kennan Ward
    WOW! Beautiful pics!!!
    Senior Member Mark Andersen's Avatar
    Feb 2008
    USA
    While I struggle a bit with the Canon wide angle glass, their tele stuff is first rate. It hard to find better telephoto glass than Canon.
    Andersen Studios Inc.
    Film Production and Stock Footage
    Epic and Red One MX rentals available
    www.markshoots.com
    Senior Member Russ Fill's Avatar
    Oct 2007
    World wide working
    I have been using the Epic on Survivor for slowmo and the thing I find is not to ask too much from it. 2K works well if your not full 300fps.. if you are around 200..240 your compression ratio is down to 6/to/1 and that helps a lot.. Also if you shoot using 3K you get a lot of the artifacts or noise to disappear. Obviously you give up a few fps but the gain in a cleaner image is well worth it for me.
    This post is the reason why I go to REDuser.net a couple of times a week.
