Thread: Need shotgun mic recommendation for exterior recording of church bells
Results 1 to 9 of 9
  1. #1 Need shotgun mic recommendation for exterior recording of church bells
    Senior Member James B.'s Avatar
    Mar 2011
    Hi
    Want to get the absolute best quality recording of some church bells. I need to pair the mic with the Zoom H4N.
    Can anyone suggest a good shotgun mic to pair with it?
    Considering these 3
    Sennheiser ME 66 Super Cardioid Condenser
    Sony ECM674 short shotgun
    Sanken CSS5 Shotgun Stereo Mic
    Any other suggestions?
    Should I go with stereo for this type of recording?
    My latest work
    [twitter] eco_bach
    "...all improvisation is life in search of a style."
    - Bruce Mau,'LifeStyle'
    Senior Member Mark Phelan's Avatar
    Oct 2007
    Schoeps CMIT 5U.
    Mar 2011
    hmm, thanks, guess i forgot to mention I am on a budget;)
    going thru these articles
    http://www.kenstone.net/fcp_homepage...tgun_mics.html
    http://www.kenstone.net/fcp_homepage...Audio-Technica AT-875r
    My latest work
    [twitter] eco_bach
    Senior Member Michael Panfeld's Avatar
    Nov 2007
    Washington DC
    Cheap: Rode Stereomic
    Sell your kidney: Schoeps Super CMIT 5U
    Karma vs Mojo Productions LLC - Karma vs Mojo Rentals LLC
    Canon FD (24,28,35,55,85,100,135,200,24-35,28-50,35-70,55-135)
    Super Baltar (20,25,35,50,75,100,150,225)
    Lomo Standard Speed (18,22,28,35,50,75,100,150,200,250,300)
    Lomo Super Speed (18,22,28,35,50,75)
    Lomo Anamorphic (35,50,75,150, 40-240 zoom)
    Lomo Zooms (20-120, 28-80)
    Angie Zooms (20-120, 25-250 "old school")
    Oct 2008
    Gorham, Maine
    Quote Originally Posted by James B. View Post
    Then rent the Schoeps.
    David Fuller
    AirStream Pictures
    RED ONE #172MX
    EPIC-M #1053
    Nov 2007
    Washington DC
    Seriously, get the best mic you can, but then, more importantly, figure out where best to place the mic. Bells are a serious challenge. They are extremely loud up close and can, at the worst, damage the capsule of a sensitive mic, or clip any detail if they are too close. On the other hand, bells have huge echo issues, especially if they are in a partial enclosure or in a tower near reflective surfaces such as nearby buildings. Then again, maybe you want that echo, to emphsize distance in a wide master shot.
    So, as with any audio job, mics can only get you so far, its really placement that drives the recording quality.
    Dec 2009
    Chatsworthless, CA
    I would consider not using a shotgun microphone at all, but instead use a stereo pair of spaced omnis or cardioid mikes. I think this will work much better in the mix, assuming no dialog and not much wind. I think this will sound more natural and be more useful than a mono shotgun. There are also M/S stereo shotgun systems, like the Sennheiser 418S, but I think there are better two-pieced M/S systems out there that will sound better. Church bells have a huge amount of dynamic range and will tend to overload all but the best preamps and mikes out there, depending on where and how you set it up.
    Note there are hundreds of hours of pre-recorded church bell library sound effects available from companies like Sound Ideas and Hollywood Edge, among many others. You may find using these will work better than anything you can record yourself, plus they won't have any background noises, wind, weather issues, and so on.
    www.cinesound.tv | location sound / post-production consultant
    Mar 2011
    Thanks for all the great info! Will probably rent for my immediate needs. Will also consider stock and in the sub $1000 range consider investing in something like the Audio Technica BP4029 AT835ST. If cost were no option would go for the Schoeps for sure.
    My latest work
    [twitter] eco_bach
    Junior Member
    Mar 2010
    Sydney
    I've recorded church bells over the years and stereo worked best.
    Church bells are meant to heard from a distance, close up they can put out very high SPL and overload everything in sight.
    Run a Google search, you get recording info and hear some examples, even then it sounds like you'll need some tests and rerecording, depends on what style you want.
    http://www.hibberts.co.uk/recording.htm#prof
    Cheers.
