Thread: Scarlet/ epic single frame stills?
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1 Scarlet/ epic single frame stills?
    Aug 2011
    10,000 Lakes
    Can you set up the camera to capture single stills?
    Or do have to pull the stills from a motion file?
    Nov 2010
    Washington DC
    At this point you have to take the still from the motion file.
    twitter @filmgent
    Aug 2011
    10,000 Lakes
    Is this something that will be added to the firmware?
    Senior Member Peter Majtan's Avatar
    Feb 2008
    Japan, USA
    YES. There is a button on the side-handle and the REDMOTE that switches between motion and still modes. It is not currently activated...
    You don't need eyes to see, You need a vision!
    www.petermajtan.com
    Aug 2011
    10,000 Lakes
    Great, I haven't lost it yet...
    Senior Member Andrew Gentle's Avatar
    Jul 2008
    Brisbane, Australia
    Quote Originally Posted by Peter Majtan View Post
    I thought that was supposed to change the way the focus algorithm works?
    You could always set your DSMC to 1 fps and then probably start and stop the recording fast enough to get a one frame .R3D file.
    @AndrewProductns
    Scarlet-X #64
    Jul 2010
    or go for the 12fsp 5K burst and pick the Best Of....?
    Stu Aull
    #199
    Alaska
    Jul 2008
    Brisbane, Australia
    Quote Originally Posted by stu aull View Post
    Well, yeah, that's a much better idea because unless you're starting recording remotely, there's bound to be some camera movement from the press of the record button. If you choose a frame other than the first or the last you'll probably find that it's sharper in most cases.
    @AndrewProductns
    Scarlet-X #64
    Aug 2011
    10,000 Lakes
    I wonder how far down the list the still feature is now?
    Mar 2012
    Orlando, FL
    will there ever be flash control?
