Thread: Noisy blacks
Page 3 of 9 FirstFirst 1234567 ... LastLast
Results 21 to 30 of 83
  1. #21
    Senior Member Matthew Scott's Avatar
    Nov 2008
    Melbourne, Australia
    That was the best RAW lesson I've had, period. Cheers Matt & Brook :)
    Feb 2008
    Chicago, IL
    Yea. That's the way I like to do it. I rate and light for 320. Results are clean and low noise.
    Quote Originally Posted by Chris McKechnie View Post
    So should I be looking at the RAW feed from the monitor or a modified LUT version?
    Red One #7209, Epic-M #1133, Scarlet-X #629, Epic-X Stage 3.5 #tbd, RPZs, Nikon G, Canon L, Leica M, Cooke iPanchro
    Senior Member Matt Ryan's Avatar
    May 2008
    Long Beach, CA.
    If you reset everything in RedcineX Pro to Default (Redcolor2, Redgamma2, ASA 800) this is what your histogram looks like:
    Everything is basically bunched up on the low end with the exception of the clipped microphone. Theres not really any separation between your highs and your lows.
    REDuser Sponsor Brook Willard's Avatar
    Burbank, CA
    Quote Originally Posted by Randall Brown View Post
    I would recommend against this STRONGLY. Rate and light to 800 ASA. Just don't rate and light to 2500 ASA, as was the case here.
    Rating the camera at 320 ASA will cause you to overexpose by 1 1/3 stops, costing you dynamic range in your highlights.
    Nov 2008
    Is it fair to say that if you light and expose properly at 800 ISO on the MX sensor, you can achieve virtually noiseless results?
    Dec 2009
    Montreal
    Quote Originally Posted by Matthew Scott View Post
    Yes. Even at 1600 (without any other pushing). also, the texture of the noise is not nearly as bad as noise on many other cameras, so when it appears, it's not the end of the world.
    May 2008
    Long Beach, CA.
    Yes, just make sure to throw as much light at it as possible. You can always bring levels down, but you can't bring up something that was underexposed to begin with without introducing noise.
    Nov 2008
    Yeah sweet, I'm not totally afraid of noise, especially pretty noise (mx noise)...thanks for the info :)
    Senior Member Chris McKechnie's Avatar
    Mar 2011
    Orange/LA County
    Thanks for the tips guys. Gosh I love this forum.
    Mar 2011
    Orange/LA County
    Quote Originally Posted by Brook Willard View Post
    Brook:
    When viewing the monitor in RAW mode, is it showing 800 ASA since that's the native of the sensor?
