Today I hooked up a mic to my brand new Scarlet to test the audio. But there is an annoying ticking noise sound in the audio.
This was the setup: AKG mic --> Sound Devices Mix Pre D --> A-Box --> camera
I used tested xlr cables and the x A-box just to make sure all connections were right. Settings on the Scarlet are audio mode "balanced" ("unbalanced" has the same result) and audio input on and at 35dB. The sound from the microphone is there without any issues, levels are good and sound is great.
But you hear a ticking noise sound, very regularly, slower then a second. It ruins the audio track. You hear it via the headphones and when you play a clip on the computer with RedcineX.
So then I removed everything from the Scarlets audio connection and the tick is still there, even without anything attached!
Running on firmware version 2.0.5
Anyone any idea what can be the cause of this??
regards,
Erwin
