Thread: Epic settings not changing
Results 1 to 5 of 5
  1. #1 Epic settings not changing
    Some of the settings on my new epic are not changing. When I adjust the white balance and the iso it registers that it has been changed, but nothing happens in the monitor and when I record at different white balance settings the images all look the same. Frame rates and shutter changes just fine.
    Anyone else having this problem?
    Senior Member Andy White's Avatar
    Nov 2010
    United Kingdom
    Sounds like you're in RAW mode.
    Nov 2010
    United Kingdom
    Go to Settings>Display>Tools> and check that 'Off' is off... but also check that 'RAW' is not 'pressed in'... if it is activated/pressed in, even turning the menu Off doesn't deactivate it :)
    So, just make sure you toggle the RAW on/off directly...
    Nov 2010
    United Kingdom
    Hi Gregory - just checking back... did you get the problem solved?
    Senior Member Will Keir's Avatar
    Sep 2009
    California
    I've seen a couple people have this same issue and taking RAW off solved it for them.
    CASE CLOSED.
    Will Keir
    Creative Director ~ Jumping Rock Pictures
    Epic X #2482 / R1 #3033
    "Why I choose film?
    The friendships, the adventure, the art."
