Originally Posted by
Tom Gleeson
Recorded a days work at project frame rate at 25fps. Camera on build 2.0.5. Playback in camera did seemed sped up. When ingested into the latest Redcine X Pro with Red Rocket the clips play too fast. When exported they also play too fast. If imported into FCP6 and slowed by 75% the clip syncs with the externally recorded audio. If I check the metadata in Redcine X Pro it says "Framerate 25" and "Recorded framerate 25"
I seemed to have ended up with a framerate of 18.75fps??? Looking at the time code slate it looks like every fourth frame is missing.
Hoping very much that I can pull 25 frames per second out of these files. Any thoughts???
