Click here to go to the first RED TEAM post in this thread.   Thread: Do i need to do black shading after each upgrade?
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
  1.   Click here to go to the next RED TEAM post in this thread.
  #21
    I'll post a sample r3d when I get a chance... that will serve as a better example.
    -- Matthew Biederman
    Do I need to black shade when switching between 5k/4k or can I store a blackshade for each?
    Gavin Greenwalt || im.thatoneguy
    im.thatoneguy[at]gmail.com | Straightface Studios | VFX & Animation
    Canon Scarlet-X package available to rent in Seattle, WA
  3.   Click here to go to the next RED TEAM post in this thread.
  #23
    Quote Originally Posted by Gavin Greenwalt View Post
    You do not need to black shade when changing formats.
    Quote Originally Posted by TheBied View Post
    Would like to see that Matt..!
    Ryanb. | PDX | Scarlet-X #639
    Senior Member Trevor Meeks's Avatar
    Jun 2009
    Sonoma, CA
    Quote Originally Posted by Ivan G View Post
    It's been a while since I've done this but do I have to have a lens on to do this properly?
    No, in fact it's best to have a body cap on the camera, and have the camera in a dark room and/or covered to prevent any light or infrared contamination.
    Jun 2009
    Sonoma, CA
    Interesting. I was doing some low-light testing and switched from 4K to 5K, which resulted in horrible noise showing up, histograms were all whacked out.... I black shaded and everything went back to normal. This was on 2.0.8 a couple of weeks ago.
  7.   Click here to go to the next RED TEAM post in this thread.
  #27
    Here's an extreme before and after example: https://docs.google.com/file/d/0B0hS...TQQ/edit?pli=1
    The after R3D is representative of the shading you should see if your camera is properly calibrated for it's current conditions.
    Note: ISO is set to 12800 to exaggerate the noise in the image.
    Dec 2010
    Toronto
    Thanks Matt!
    Senior Member Josh Beadle's Avatar
    Sep 2011
    SoCali
    Thanks Matt,
    How about posting a sticky official document on all things Black Shading: when, how, why, issues, examples . . . everything there is to know on the subject. This would be very helpful.
    I've heard that big changes in ambient temp creates the need to recalibrate - shouldn't it be a big change in the sensor temp as read out on the EVF? Like if it drops from 50C to 44C. Who cares what the temp is outside - it's inside on the sensor that drives noise. If that is correct, then what is the on-sensor temp spread that necessitates a recal?
    Josh
    Epic-M 1388 aka "Black Sheep"
    ATV FamFun
    It's not your camera's fault:
    http://www.youtube.com/watch?v=jJm2EGNIod0&feature=related
    "Your first 10,000 photographs are your worst"
    Henri Cartier-Bresson
  10.   This is the last RED TEAM post in this thread.   #30
    Quote Originally Posted by Josh Beadle View Post
    Thanks Matt,
    I think a more appropriate place for the information would be the Ops Guide. But I agree, black shading needs better documentation our part.
    Sensor temperature certainly plays a large role in the overall noise of the sensor. From my experience, anywhere between a 5 and 10 degree swing you'll start seeing better results in the dark with a re-calibration. Again, that's on the sensor temperature.
    The first temperature we readout in the bottom status bar is the sensor temperature and the other is for other critical internal electronics. The sensor calibration temperature is visible in the system configuration menu.
    Looking forward, (in addition to making the entire calibration process smoother) we're looking to add warnings if the camera detects a deviation between the current sensor temperature and the calibrated temperature.
