Thread: DaVinci Resolve 8.2 support for Tangent Element Panels Menus and Controls
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
  1. #11
    Dec 2009
    Montreal
    Hi Mike!
    Agreed. But realize that many of us will never have a spare 30K for a BM board, as many of us shoot as well, and have lots of cash put aside for prod gear at the same time. Even for a full time colorist in most markets, 30K is a lot, especially since in many countries, banks are very, very tight right now so it would have to be cash up front..
    Add to that curved fall-off for HSL qualif., (Not just linear like now), the ability set a different Red Settings for each Red clip instance (like in Premiere) and better still Red Settings within nodes, limited by qualifiers. Also a Transparency variable (for using qualifiers and windows to make layered comps on the conform timeline) Also, let me copy and paste curves between Hue-vs panels (now I have to manually make the same points if I want a particular hue to be de-sat AND shifted.) Let me reset any curve point back to default un-moved position with one click. Let me use a separate display LUT for my external monitor and my viewer window. and most of all give me nice big curve windows, with a few well-placed points I can control up and down via control surfaces.
    Not sure what you mean by edge windows? You mean like a vignette? You can always make a centered square and invert it. (Likely that's not what you mean)
    Quote Originally Posted by Rob Ruffo View Post
    By "edge window" I basically mean a single edged LPW that aligns itself on one of the four edges of the frame. This means that the window reaches from one of the edges (left, right, top, or bottom) into the image, removing the need to create an LPW, resize it, reposition it, and rotate it in order to mask off one edge of the frame. All you do is enable the window and you can control the single visible edge in terms of position, softness, and rotation. This is very useful and efficient for things like sky and toplight grads, as well as quickly minimizing light at the bottom of the frame (things like bounce light on tables, hot kicks from streets that have been wet down, and edge flares, among many other things). It also allows very quick creation of "cutters" to shape light on the corners of the frame, a very common technique for many colorists.
    As a point of reference, Baselight has these, and they are a great time saver.
    Senior Member Luis Otero's Avatar
    Orlando, FL
    I just moved from the Eclipse to the Element, and they are just a big improvement. Other potential mappings may work for different colorists, so it will be great to have such re-mapping ability.
    Am I missing where the "Render" button is mapped in? It could be, for example, in the "B" button of the main three-wheel panel.
    Luis Otero
    Epic-X #1616
    (Old Red One 711)
    I was scammed, and I love it...!
    Digital Emulsion
    Orlando, FL
    IMDB: www.imdb.com/name/nm3889059/
    Senior Member Paul Provost's Avatar
    Aug 2008
    Luis, can you please elaborate on Element's advantages over eclipse? wondering if I need to list mine on eBay....
    Colorist | Hollywood, CA | www.4kfinish.com
    http://www.facebook.com/4kfinish
    Twitter: 4 kfinish
    Orlando, FL
    Paul,
    As any new product, there is room for improvement, so I do not cllaim it is perfect. However, even this first mapping on this release, everithing is much more logically organized by task, or area of grading functions. And as important as the mapping, it contains WAY more function already maped than you can find on the Eclipse. Let alone the ergonomics. The design and footprint is sexy, and it feels very confortable during those long sessions.
    The transition from the Eclipse to the Element combo has been as seamless as it could be due to such logical way that the maping was put together. I do not regret a bit the decision to move to the Element. Just go to the BMD page, and download the mapping documentatio it has been published, and you will see all such functioins, and how they have been grouped. Actually, there are more function in the submenus that I found out than the ones they published.
    Hope this helps you in making such decision.
    Luis Otero
    Epic-X #1616
    (Old Red One 711)
    Digital Emulsion
    Orlando, FL
    Aug 2008
    how about the "feel" of the rings and color balls? what did you do with your eclipse?
    thanks, Paul
    Twitter: 4 kfinish
    Orlando, FL
    I like the feel, but that is subjective. One of our Jr. colorist also reported that he likes it very much, too. The ergonomic that was put into it is really something we admire and appreciate.
    We have not decided yet the destination of the Eclipse.
    Luis Otero
    Epic-X #1616
    (Old Red One 711)
    Digital Emulsion
    Orlando, FL
    I would LOVE to see the ability to move the pos of a power window on screen with the extra joyball. That or like the Tangent did with Apple Color, you hit the alt button and that allows you to repo windows using the main joy balls. If I could have a separate panel setup to just manipulate PowerWindows it would be fantastic. I'm kind of surprised you can buy these in a modular fashion yet you're stuck with how BM decides to map the functions. Again the Tangent used with Apple Color worked the best as we had that little app that allowed us to remap all we want. I was really hoping to do this with Element. If I can't customize which panels and how to map their functions, I'm not sure why I would use an Element and not just keep with a Wave and sustain how I'm disappointed with how it's functions are hard-mapped.
    chris smith :: sugar film production
    Quote Originally Posted by M Most View Post
    By "edge window" I basically mean a single edged LPW that aligns itself on one of the four edges of the frame....
    ...As a point of reference, Baselight has these, and they are a great time saver.
    Agreed - would also LOVE to see this in Resolve.
    I would love to see both qualifier picking via that track ball "IE mouse mode for the love of god!" Why is that so hard! Who wants to keep moving over to a mouse to click stuff! Also copy and paste grades from the stills in a more logical fashion would be nice. Yes agree memories and jump to timecode or shot #
    CJ
