Click here to go to the first RED TEAM post in this thread.   Thread: Histogram not tightly enclosed by raw-bars as in manual
Page 11 of 13 FirstFirst ... 78910111213 LastLast
Results 101 to 110 of 122
  1. #101
    Senior Member Patrick Grossien's Avatar
    Nov 2008
    Germany
    Quote Originally Posted by TheBied View Post
    The histogram as it stands shows you what the color science is actually doing to the data. Just as you can view the histogram in RCX while tweaking any parameter, the camera offers the same flexibility.
    Matt this is exactly where I am having problems in understanding. I could care less about gap or no gap as long as I know how to read it. So please do explain a bit more. For example how do we have to understand the 0 value in the highlights in the higher 80%? I understand the right side of the histogram to read 100% value bright white but it seems that this is wrong. Could you please explain more in depth what is what or point me into the right direction where to get the information. That would really be helpful if we knew what we are looking at!
    Thanks a ton in advance!
    SCARLET-X "Mathilda"
    "Life is full of obstacles. They never end. The ones that get past them have the richest life."
    jim jannard
    "if your pictures aren't good enough, you aren't close enough."
    robert capa
    [QUOTE=TheBied;1036530]
    I filed a support ticket not long after I received my Epic X for just this problem. After several weeks of back and forth they concluded nothing was wrong. Then I contacted my Bomb Rep. and explained the problem and sent in it. They sent it back saying nothing was wrong. Finally I spoke to an individual who admitted it was a bug they thought they had squashed. This was two firmware releases ago.
    My question Matt. Is the camera recording the full range capable and displaying it truncated? The highlight data in RAW or at 320iso never go beyond around 85-90%. Or is it recording a limited range of data and then the color science is stretching it back out to 100%? Thanks.
    So now there's a new page about exposure tools in the "Learn" section of RED.com: http://www.red.com/learn/red-101/red...exposure-tools
    After reading it I'm more confused than ever about how to use the histogram. The text makes no mention of how the histogram behaves when monitoring in RAW mode (i.e. "OFF" is highlighted on the OSD). In fact, the text kind of implies the histogram is always affected by current ISO and look settings, as if there's no RAW mode at all. The last paragraph reads, "Furthermore, ETTR can be misleading since the live histogram doesn’t represent raw image data."
    And yet I can see the histogram changes visibly when switching to RAW/OFF monitoring.
    Also, the page does not clarify the strange behaviour reported by some users in this thread. Like how the histogram shows no gap on the right for a while, and then suddenly the gap appears again.
    Someone educate me, please.
    Quote Originally Posted by Petri Teittinen View Post
    Apparently the Epic's and Scarlet's in this thread do not work in the same way as the ones at RED HQ. Theirs are gap free, ours come wih the tag "mind the gap"... :)
    Carl Dieker
    filmmaker / Stockholm
    www.podalidafilm.com
    Just updated to the last release firmware and it appeared on my Scarlet.
    In my case the left side is ok, but on the right there is a gap.
    It wasn't there before on older firmwares.
    EDIT: No gap on higher ISOs
    "Production value!" ©
    Senior Member Eric Haase's Avatar
    Mar 2009
    I believe the histogram represents what you are viewing- if that happens to be red gamma or any gamma curve applied with ISO and all your look settings then the histogram will reflect the image with those settings applied. If you toggle to raw view and the histogram changes then it's showing you a histogram based on raw. The goalposts however are always representing the raw data. The raw data histogram should approximately match the histogram at ISO 320.
    Eric
    cinematographer
    www.ericjhaase.com
    Mar 2009
    I'm not sure I totally understand WHY the histogram NOW has gaps before the clip points. I understand that it is reflecting the metadata and that the different gamma selections roll off the highlights in a different way so I think that's why there is a gap. RG3 never lets values get to 100. (nor does RG2). When I load a clip into RCX with severe overexposure the whites never get beyond 97 or 98 on the waveform. My question is:
    WHY NOW? It did not used to be like this just a few months ago. So why the change? I find it extremely frustrating that a change like this is made, which to the end user represents a significant change in the way we use and understand the histogram tool. Yet it gets a half sentence line in a release note. This is yet another reason this camera is viewed as unreliable or confusing to many. I'm all for improvement but it's impossible to test every feature of every new build every time the camera is updated.
    Furthermore, the zebra function doesn't work. Shooting a clearly OVERexposed scene with zebras set to 98 to 108. Look at the following images. Redgamma 2 is selected. At ISO 500, zebras are present and Exposure check shows red overexposed areas. At ISO 400 zebras disappear but exposure check still shows red overexposure. Is this a known issue?
    Eric
    cinematographer
    www.ericjhaase.com
  #108
    Quote Originally Posted by Eric Haase View Post
    Zebras are showing the IRE value which is a video out level measurement (http://en.wikipedia.org/wiki/IRE_(unit)); This is operating on the cooked data (meta data is applied).
    The exposure check mode shows where the raw data is being clipped (or in danger of being clipped).
    It is expected that they would behave differently based on your meta data settings.
    Mar 2009
    Quote Originally Posted by Trent Lillehaugen View Post
    That is very counter intuitive. Most operators or DPs would use the zebra To set exposure and keep an eye on what is blown out. How can something be blown out on raw exposure check but be BELOW 98 IRE at 400 ISO in red gamma 2 (500 in rg3)? This makes no logical sense. The sensor is clipped. There is no information in that highlight. But the zebra indicates the value is below 98??
    Also, can you please tell me why the change was made on the histogram? It used to go from goalpost to goalpost in a full exposure in rg2. I shot hundreds of days that way. Now, when the histogram approaches highlights there is a gap between the brightest it can represent and the goalpost in rg2. Why the change?
    Thanks for your replies.
    Eric
    cinematographer
    www.ericjhaase.com
    Senior Member Brian Boyer's Avatar
    Jan 2011
    I'm going to take a stab at explaining this just to make sure I'm understanding it correctly. I may end up getting my arse kicked. :-)
    It's only counterintuitive if you think about the Scarlet as if it's a video camera...it's not. What you say makes perfect sense for something like an EX1 or F35, which don't record raw sensor data and have no concept of metadata.
    It seems as if you're thinking that the IRE values are somehow a subset of the wider sensor values on the same scale and that's not the case. One can inform us about the other but they don't drive one another, at least not in the way that you seem to think. They measure different things at different stages.
    After you set your frame rate and shutter angle/speed, the ONLY other on-camera control that has an effect on how the sensor gathers light is the aperture control. If you set up a scene where you're shooting an evenly lit, pure white background but you're not clipping the sensor because you've adequately stopped down to just below the clipping level, you can crank the ISO all the way to 12,500 and make the zebras scream but it will not overload the sensor because you're merely changing the metadata. The only ways to clip are to open the aperture or add more light to the scene.
    Well, the converse is also true, which is your situation. You're blowing out portions of the sensor but you can get the zebra to go away if you lower the ISO. The zebra is based on IRE values which ARE driven by ISO (they have to be), but the ISO value and the REDgamma settings are metadata. The metadata has no effect on the raw sensor data.
    It may help to think of it like this: raw sensor data --> metadata --> video data. The IRE and zebra values are downstream of the metadata and therefore the metadata is cooked (as Trent put it) into those readings, but they're only really relevant at the video outs. That explains why you can lower the ISO and eliminate the zebra but still have a clipped sensor. IRE just cares if you're going over 100 at its stage, not about what happened upstream.
    "What happens upstream is none of my business." - IRE
    Again, RED's cameras understand video but they're not video cameras.
    Zebra and IRE are relevant to any VIDEO signal present at the Scarlet's VIDEO outputs, namely the SDI, HDMI and lcd/evf ports. At that point, signals must conform to video standards and it's where it makes sense for the metadata to have its impact because that's where those settings "stick", whether they're going out to an external monitor or recording device. It's a different space than the raw data.
    IRE (video space) doesn't care if you have headroom in the highlights or not - go above 100 and you're clipping. If you're not clipping the sensor but you are above 100 IRE you can bring the levels down and reclaim the highlights in post.
    Exceed 100 IRE but clip the sensor and bringing the levels down will do you no good in terms of reclaiming the highlights because they're simply not there.
    Do what you have to do to to get your video feed looking right for monitoring or external recording but, by all means, protect your "negative" and don't clip the sensor unless you can live with the outcome.
    Cutting out soft shadows in Photoshop tutorial
    YouTube | Vimeo
    www.harbonder.com
