Thread: CANON 70-200L scarlet AI eos mount
Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
  1. #21
    Member JamminJG's Avatar
    May 2008
    Sangre De Cristos
    I have the canon 100-400 and the ti canon mount on the way. that's why i went with ti. However, i think i'll still need support. not a lens i believe i'll use much, but i am all about versatility!
    Senior Member Casey Green's Avatar
    Feb 2007
    By the way, anyone with an Al Canon mount that wants to sell it to upgrade to the Titanium, please PM me. I'm looking to buy the Al version.
    Quote Originally Posted by Trevor Meeks View Post
    What do you mean image shift?
    http://www.reduser.net/forum/showthr...5-Impressions)
    Quote Originally Posted by Evin Grant View Post
    Basically in order for the small motors in AF lenses to move the focusing elements in the lens at speed they need to have an inherent amount of play. If they are too tight the tiny motors will not be able to focus much faster than you can manually. This looseness means that when you change direction on the focus ring the image actually moves slightly, usually left to right but sometimes up and down too. On a small screen this doesn't always seem like such a big deal but on a 40' projection screen it's incredibly jarring and distracting. Things get even worse with the two 24-70 zooms, both quite good optically, but because the front ocular bells both telescope out of the main body, because of this they are prone not just to image shift while focusing but also zooming or just from the normal movement and bumps of the camera.
    Senior Member Pete Lutz's Avatar
    Nov 2011
    Asheville, NC
    Quote Originally Posted by Sunny Jhooty View Post
    how do you find the build quality on that lens support?
    It's not the beefiest lens support I've seen, but it's ample for the Canon 70-200. It's actually more solid than I thought it would be, it's well pretty well made. PM me if you want some better pictures of it, I'd be happy to email you some.
    Jan 2012
    Santa Monica
    Quote Originally Posted by Pete Lutz View Post
    I have that lens, and I use the x easy riser, LW 15mm Bracket and an inexpensive lens support I found on ebay, I already had some 15mm rods. I needed most of that stuff for my follow focus, so it wasn't that big of an investment for the one lens.
    Hi Pete,
    Thanks for the suggestion. I just ordered one.
    Sam
    Scarlet #01058 'VFX-1'
    Pretty good set of Canons.
    Senior Member Ivan Kovax's Avatar
    Nov 2009
    Tokyo, Japan
    Yeh... I have hung this lens all day off my epic the other day, handheld too. Didn't worry me once. Well made mounts. The titanium mount has a double lock mechanism which will hold anything in place (within reason), and I am assuming the aluminium will have the same, however for safety it is always best to have support for larger lenses ...
    One thing to watch out for - some ACs on that shoot were a little slow to learn... they tried grabbing and lifting the camera via the lens and the handle a few times...
    hth
    Ivan
    Junior Member Sunny Jhooty's Avatar
    Oct 2011
    Vancouver, BC
    pm sent
    Nov 2011
    Los Angeles, CA
    Not to hijack the thread, is anyone using this lens for a run and gun application?
    Senior Member Marc Berger's Avatar
    Dec 2007
    France
    Quote Originally Posted by Michael Zeleny View Post
    Yes, and its a fantastic lens for it. AF in still mode works with it very well ("point and shoot") , IS works great too. I have the AL mount and its sturdy and I doubt Canon made such a great mount themselves in the EOS EF camera history. Anyway I never saw a better one and I owned a lot of Canon EOS EF cameras. The Red AL with its double locking holds securely heavier lenses then the 70-200 without lens support (Keep in mind its always more secure to use a lens support, but not always necessary ).
    One more good reason for run and gun with this lens is the diameter for screw in filters: 77mm. This filter size is easy to find around the globe and not to expensive to buy.
    Senior Member Trevor Meeks's Avatar
    Jun 2009
    Sonoma, CA
    Quote Originally Posted by Casey Green View Post
    I'll trade you my AL for your Ti
