I finally installed a Red Rocket card into our Mac Pro Tower and was running some test. The results are a little confusing to me. Our system has 12GB of ram, and all the media I'm working with lives on a three drive striped RAID which gets around 200 MB/sec for HDD speed tests. The rocket is very impressive during 4K realtime playback and 5k full debayer and half-res playback, but during transcodes, it seems like it is limited. At first I was having an issue with RedCine telling me the card was installed on a 2x PCI slot, even though it was installed on slot-2 (8x). I then tried various configs and realized the Decklink SDI card was causing issues until I removed it from the tower. After pulling it, the Rocket registered as a 8x connection and all was good. I then tested various settings for 1080p outputs using clips that were both 2k and 5k from our Epic. No matter the debayer settings or output resolutions (to eliminate software scaling) I seem to be only getting realtime or slightly slower transcodes. I did a job recently and was getting about 18fps transcodes in Davinci on a 1080 project from 4k source footage from the Red without a Rocket (I only have one ATI 5770 card). Davinci seems to output faster than Redcine without a rocket or using Redline. Since redline doesn't support using the Rocket to my knowledge, I have no way of increasing the speed. What I'm wondering is why the rocket can buffer a 2k clip way faster than it plays, but during transcodes it barely gets realtime performance? Also, when testing in Resolve, the transcode plays out realtime, then dips to 0fps for a second, then picks back up for a few seconds and dips back to 0. It's not a consistent realtime playback. The same thing seems to happen using redline in Redcine where all processors will chug away for a few seconds then it dips to a halt for a few seconds, and continues the cycle. I need to run some more tests without the Rocket to compare, but has anyone else experienced this and is there any way to get 5k 1/2 debayer or 2k full debayer to transcode faster than realtime in any program? I feel like if the Rocket can do 4k realtime, I should get 2k MUCH faster, but I can't seem to...
