Thread: Help audio only works at 24 fps
Results 1 to 7 of 7
  1. #1 Help audio only works at 24 fps
    Junior Member Dennis Falsing's Avatar
    Nov 2011
    Christiania, Denmark
    As soon i go to 25 the audio indikator missing?
    Scarlet X - 891
    Senior Member Nick Gardner's Avatar
    Oct 2007
    Baltimore
    Are you changing your time base to 25 or are you changing your frame rate? Because if you just change your frame rate, then you are in varispeed mode and there is no audio. If your time base is 25fps then it should work fine.
    Nick
    Nov 2011
    Thank on a job now and Don,t have the manual White mé werder do i change timebase sorry for stupid question
    Scarlet X - 891
    Senior Member Nick Wernham's Avatar
    Oct 2011
    Toronto, ON
    1) Go to the "Settings" menu at the top of the screen.
    2) Open up the "Project" menu.
    3) Select "Timebase".
    4) Pick your timebase. :)
    C.E.O. of Wernham Entertainment Inc.
    Current Project(s):
    "Business Ethics" [Completed Short]
    "Public Service" [Short in Post]
    "No Stranger Than Love" [Feature in Pre-production]
    Co-Owner of Epic-X #3805 "Hentgen" & Scarlet-X #557 "Stieb"
    Nov 2011
    Thank you :) you saved mé
    Scarlet X - 891
    Oct 2011
    Toronto, ON
    No problem. Good luck with the job!
    If you need the manual for anything else then go here: https://www.red.com/support/all/downloads
    The "Scarlet Operation Guide" is the first link on the right side.
    Current Project(s):
    Senior Member Josh Negrin's Avatar
    Oct 2008
    Awesome thread, guys. This really is a community.
    Josh Negrin
    All your base are belong to us
    IMDB page
