Thread: MXF with synced sound from RCX can't be played
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    Junior Member
    Aug 2011
    Munich, Germany
    Quote Originally Posted by martinnoweck View Post
    i assume the r3d files and the audio share the same timecode?
    Yes they do. And brought into Media Composer i saw that also audio and r3d files that RCX wasn't able to link share timecode.
    So I dumped all the MXF I transcoded until now and now export them without audio.
    This audio syncing in Avid really works pretty good.
    But are these combined audio and video files then saved as stand-alone files? It would be ideal to have a MC project only I work on until I got the desired MXF with sound and bring these then into a new project so that the editor doesn't see all the mess with all the unsynced files. Does that make sense?
    Aug 2007
    Boston
    An AutoSync clip is always a subclip that references two sources; one for picture and one for sound. In the case of true double system recording this is essential to the post workflow as the BWF import keeps all the metadata in the BWF file that gets lost when syncing in REDCNE X as well as other dailies apps. Also having the flexibility to sync only the mix track but still have access to the ISO tracks via a match frame is fantastic for the editor.
    But in your scenario, it is only being used as a workaround for an issue with REDCINE X, so the advantages aren't as obvious, unless there is a MIX and ISO tracks that you would like to manage more easily. So when working with AutoSync clips, you will always have V clips, A clips and the resulting VA clips. This comes down to basic organization. I create a folder for original sources, in there bins by day and type. They the synced clips are moved to another bin which is what the editor will eventually use. I have seen large studio level features end up with projects that have up to 4000 bins organized in folders and such by the time they get to the end of the process.
    The evolving role of DIT and Data Wranglers to become post "assistant editors" is an an interesting and challenging one. It has been a while that the cutting room doesn't sync dailies and expects that from the facility which makes sense for many program types and schedules and in others it doesn't. But now that facility function is moving on set with "dailies" apps that have different strengths and weaknesses, and data wrangler types that don't have post editorial management skill sets, with the expected reporting, flagging, metadata management and organization is being lost. And that is not a good thing.
    I am still old school when it comes to projects that I edit (features). I insist on syncing the Media Composer for full control of tracks, metadata, and management. There is plenty of evolution and innovation that be done between the on set dailies applications, training, and the NLE being used for editorial to streamline a lot of this.
    Michael
    Ernst Lubitsch
Tags for this Thread
View Tag Cloud
