Thread: H.264 from RedCine-X...What is the optimal data rate?
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    Senior Member Von Thomas's Avatar
    Jun 2008
    Quote Originally Posted by Mathieu Ghekiere View Post
    What are you then using as source in Compressor? I suppose it doesn't take R3D, so do you use a Prores format to render out from there?
    Or would it work with the Quicktime Proxies (reference movies) that you render out from RCX?
    Mathieu,
    I normally produce ProRes 422 LT, then send that to compressor.
    Von
    Von Thomas
    IATSE Local 600 DIT
    International Colorist Academy
    www.icolorist.com
    www.digitaltechnyc.com
    www.vonthomas.com
    http://reddigitalmotionandstill.blogspot.com/
    RED #5721
    Junior Member
    Oct 2011
    Washington, D.C.
    Does anyone else have trouble limiting the data rate for H264 when using RCX-Pro? I'm on build 14, and if I set Quicktime to export 480x240 (for quick reference to send to transcriber) and limit the data rate to 500kbps, the file comes out larger than it should be, and quicktime says it's about 2,500kbps.
    I'm on on mac pro, 10.5.8.
    EDIT: Figured it out. Redcine is in KiloBytes (KB) per second not kilobits (kb) per second. Silly me.
    Does anyone know how to compress audio in redcine to something like AAC?
