Click here to go to the first RED TEAM post in this thread.   Thread: Scarlet problems,
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
  1. #1 Scarlet problems,
    I have a few problems, the first one was unable to black shade, the second issue is the amount of noise in the blacks, even at 50 ISO, it's not usable and starting a film in 2 days. The third one is that the camera picture jitters when I pan and it's obvious on the monitor, but worse still it seems to record that way. I just cannot use this camera in its present condition. See photo sample
    New York, NY
    You still cannot do a black calibration? If you can get it to work that should help your noise problem a lot.
    What do you mean by jitter? Could you post a sample?
    Noah Yuan-Vogel | noahyv.com
    Scarlet-X #01031 LEOLO
    Oct 2010
    Detroit, MI
    is that still in redlogfilm? if so, your always going to see a lot more noise with RLF as your gamma curve. as soon as you bring the blacks down to a normal level the noise will go away
    J.H.C Scarlet-X #1636 (Sherry Baby)
    http://Coleman-Media.com
    Junior Member
    Feb 2012
    Europe
    Did you update to firmware 3.0.0?
    Quote Originally Posted by Joseph Coleman View Post
    No it was set on REDgamma3 with flut pushed high to exaggerate issue, in fact it doesn't matter which image look setting on Redcine, those vertical lines are very apparent on all dark shots. Download (still) sample here: http://www.intermediaarts.com.au/test.RMD
    Quote Originally Posted by Isak Dinesen View Post
    Yes twice, and factory defaults also. I have some test shots prior to update and they are perfect.
    Senior Member Les Dittert's Avatar
    Sep 2011
    Quote Originally Posted by Joel Mielle View Post
    No it was set on REDgamma3 with flut pushed high to exaggerate issue, in fact it doesn't matter which image look setting on Redcine, those vertical lines are very apparent on all dark shots. Download sample here: http://www.intermediaarts.com.au/test.RMD
    that's the meta data file, you want to post the r3d .
    -Les Dittert
    Quote Originally Posted by Les Dittert View Post
    Here's the correct link. Look at the vertical noise stripes on the darks, even apparent on skin tones.
    http://www.intermediaarts.com.au/test.r3d
    Junior Member
    Feb 2012
    Europe
    If it worked on the pre-3.0.0 then maybe you should downgrade to 2.0.5 (you can still get it from red.com)
    Then you could do your shoot and RMA the camera afterwards and let Red know what the problem is
    Aug 2008
    Good luck brother...this is not good...I am scared now of my scarlet!!
