Thread: Scarlet audio HELP!
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1 Scarlet audio HELP!
    Sorry if this has been covered but I haven't found a link where it solves the problem.
    I basically found the link on here of how to hook up a Rode mic with adapter to work through the mic 1&2 inputs on the scarlet...in my case a sennheiser mke400
    When my headphones are plugged in the scarlet...i can hear the mic picking up what i need and it sounds fine...just need it for reference audio
    My problem is...when transferring the r3d files or checking back in redcinex...there is no audio, no audio timeline etc
    I am using FCP7 and a trial version of Adobe Premiere Pro CS5.5...still no audio
    would love some help on this and to avoid busting out my H4N for every bit of audio i may need
    Daniel ;)
    A wise man once said ''Where you end up is where you are'' (The Brady Brunch)
    Aug 2010
    Switzerland
    Hi Daniel,
    have you tried installing the new RedImporter for Adobe Premiere? It is supposed to have audio playback.
    Mar 2011
    Toronto, ON Canada
    Just curious. try spitting out a quicktime from redcine. I had a strange instance when I couldn't hear the audio in RCP, but I could in the quicktime. After installing an earlier build of RCP, it began to work. Then I went back to the latest build and it began to work.
    ___________________________
    10 frame handles
    Vimeo
    EPIC-X "SHAI"
    thanks for the reply guys
    yep got the new red importer ...still no audio
    also tried exporting a quicktime file (first thing i did) ha
    im also trying to make sure that even though I'm hearing audio through the scarlet that its reading it properly...as in waveforms on the touch screen
    but i can't seem to find the audio wave form on the screen?
    Mar 2011
    Toronto, ON Canada
    wait... so you don't see the audio levels meter active on the screen?
    Quote Originally Posted by Daniel Peters View Post
    10 frame handles
    Vimeo
    EPIC-X "SHAI"
    thats the weird thing...the audio meters pop up on the screen for like a second
    so even though i can hear audio, I'm not sure if its getting to the scarlet ok due to the audio meters not showing up
    Are you undercranking? I remember the audio meter flashing by like that and then disappearing when I was shooting 5K/12 fps.
    no...not undercranking, shooting 4k 25fps
    I know people hate when people bring back old threads but was this issue ever solved? Having the same issue with an important project I shot... Could hear audio during recording, no audio in red cine x even after export.
    Scarlet #532: YAMATO
    Mar 2011
    Toronto, ON Canada
    Try another player like the RED player, or try Premier CS6 to see id the audio is there.
    10 frame handles
    Vimeo
    EPIC-X "SHAI"
Tags for this Thread
View Tag Cloud
