Thread: 16 core/32 thread/64GB RAM Mac setup, but not fully working yet.
Page 1 of 5 12345 LastLast
Results 1 to 10 of 41
  1. #1 16 core/32 thread/64GB RAM Mac setup, but not fully working yet.
    Jul 2009
    Santa Monica
    Well, I got the new system built today, but the drivers aren't fully working yet.
    Still, check this out. 16 real cores, 32 threads, 64GB RAM. (EVENTUALLY coming soon to Apple, or not).
    Jul 2009
    Santa Monica
    Edit Update: CineBench CPU test is 24.5 in Win7.
    Problem is, the latest Lion kernel is not made for this chipset yet. But everything is extremely fast in Windows 7.
    This is the most recent set up with 128GB RAM and RAID test.
    Get a Red Rocket if you need it.
    Which motherboard did you decide on?
    I've got a couple SuperMicro X9DAi boards on order. waiting....
    - Jeff Kilgroe
    Jul 2009
    Santa Monica
    Hey Jeff. Yup, same board. X9DAi. This is running dual E5-2690's. Lion loaded like a charm, but driver issues. If I had the patience to keep trying drivers, I'm sure it would work.
    I'm only using a Quadro 1800 card, but I'll try running some benchmarks. Let me know if you have any favorites. (windows 7 for now).
    Feb 2011
    Pearland, TX
    My word.
    Senior Member Josh Beadle's Avatar
    Sep 2011
    SoCali
    I found out tonight that my 2010 Mac Pro 12 core only supports 64GB of RAM. Tried 96GB and the fan would kick on full speed after running low stress work. Would only shut down if I put the thing to Sleep. Did the SMC reset and even took it to the Mac Store (worthless).
    Also surprised that 3 SSD 6G OWC drives in RAID 0 off the main docks run at 540mbs while the external G-Speed 24TB with Atto board runs at 800mbs in RAID 6. Seems that the SSD's have some kind of compression going on that slows them down.
    Waiting for a BT Red Rocket this week. Thing plays back at 1/4 now. Could be happy with that but looking at transcoding speed as well.
    BTW: Jeff Kilgroe is THE MAN!!
    Would pay admission to see his workspace
    Josh
    Epic-M 1388 aka "Black Sheep"
    ATV FamFun
    It's not your camera's fault:
    http://www.youtube.com/watch?v=jJm2EGNIod0&feature=related
    "Your first 10,000 photographs are your worst"
    Henri Cartier-Bresson
    Quote Originally Posted by Josh Beadle View Post
    Interesting... Did you get the RAM from OWC? If so, talk to them about it. Have you rotated modules around to make sure you don't have a bad one?
    They do, as all SandForce chipset based SSDs do, use on the fly compression. It's great for the right kinds of files. But for incompressible files, such as H264, ZIP, R3D, JPG, etc.. it doesn't help. And those advertised speeds that seem so amazing on the SSDs will fall to half or even a third of what they claim when you transfer those files. Especially large ones like R3D clips where you can easily have 100's of GB worth!
    Rocket will help the transcodes for sure. Playback at higher resolutions also helps, but you'll find that anything over half is kinda unnecessary unless you're spot-checking for noise/grain or other artifacts. On most systems, RC-X still struggles even with the Rocket at half res playback or better because the GUI interface can bottleneck with scaling and LUT application. They also don't use a whole lot of RAM for cacheing of what the Rocket processes ahead on playback and that can get real annoying at times.
    Hehehe.... You would want your money back. ;)
    - Jeff Kilgroe
    Sep 2011
    SoCali
    @Jeff
    Yup, OWC RAM. I'll try rotating it tomorrow - worked after removing 2 x 16GB chips so left it at that. Really, 64GB is plenty since, as you say, RCX doesn't seem to utilize all that much.
    What is the speed % diff between having 2 chips in each dock vs 3? Heard (probably from you) that best results had from installing RAM in 3 out of 4 slots. Got 2 x 16GB in each dock now. Seems speedy.
    Josh
    ATV FamFun
    Senior Member Will Keir's Avatar
    Sep 2009
    California
    +1
    Good way to waste a few hours.
    Will Keir
    Creative Director ~ Jumping Rock Pictures
    Epic X #2482 / R1 #3033
    "Why I choose film?
    The friendships, the adventure, the art."
    Belgium, Antwerp/Ostend
    really want to build similar system , however I'd like very much to use Smoke for Mac on it. Would this be possible at all???
    2x Red Epic, audio and image postproduction in Antwerp. 2x recording studio with 5.1 surround.
    www.nuhollywood.com
