Thread: RedCine 1.0.74 output BRIGHT !
Results 1 to 3 of 3
  1. #1 RedCine 1.0.74 output BRIGHT !
    Senior Member David Nardini's Avatar
    Jan 2007
    Hampshire, UK
    Hi all,
    Running : OS X 10.4.11 / RedCine 1.0.74 / QuickTime 7.3.0 (MacPro 8-core with ATI X1900)
    Working within RedCine is fine (library / player) ... after setting attributes for clip, on output (to QT or DPX or TIF etc ...) the output is way off ... very very bright !
    Output from RedCine build 60 (I think) was fine.
    Anybody else having this problem ??? Happy to compile some screen grabs if more info required before you can help me out ;-)
    Cheers
    David Nardini
    The artist is nothing without the gift, but the gift is nothing without work
    Senior Member Daniel Reichenbach's Avatar
    Biel-Bienne, Switzerland
    Had same problem, cut off all burned in infos like timecode ASO (ad nothing, in the right part of the output menu), then it should be ok.
    Daniel Reichenbach
    Director/DP
    EPIC X 109
    www.elementp.ch
  3. #3 ohhhh ...
    Jan 2007
    Hampshire, UK
    Culprit seems to be the previous 'preferences' ... cleared out /Library/Redcine contents (OS X), restarted Redcine and hey presto all is well again ;-) ...
    Phiew ... guessed at this from another thread on QT issues ...
    David Nardini
