Thread: RED MX IMAGES APPEAR BETTER THAN SCARLET-X
Page 7 of 13 FirstFirst ... 34567891011 ... LastLast
Results 61 to 70 of 121
  1. #61
    Nov 2008
    London
    'radfilm' - real names on this forum - just taking a look at your films on Vimeo........Dana Gonzales be real proud of yours!
    Dec 2009
    Montreal
    Quote Originally Posted by Scott Crawley View Post
    If you measure in lux or fc, then you don't need to reference ASA either, no?
    ASA was great when it was a language we all understood, but ASA is to digital imaging what the urban dictionary is to the English language, or iTextbooks might be to history. But I digress...
    Well the Epic/Red have an Iso - and what you intend on set will automatically make sense as a setting starting point in Resolve/Pablo/Etc. (regardless of what you set in metadata - the colorist will quickly figure things out unless they're incompetent). Parts of the shot may later be determined to work better one stop above or below, but the point is you work around a target, otherwise there is no land to build you lighting plan house on. LUX and fc really have no quick and easy on-set meaning, at least not for me.
    Jul 2009
    Quote Originally Posted by Rob Ruffo View Post
    Yes, of course. Thanks for taking the time to answer that seriously. I guess I was reaching a little to illustrate an idea that is a response to the current confusion which I share to some degree. When you hear folks explain a method that seems to turn the logic at your foundation upside down, and you understand that one day soon ASA will have no real meaning at all you begin to search for a new way in which to ground yourself.
    If there is something in this 800 ASA methodology that in a practical way does enable us to somehow pull more dynamic range out of the sensor, I would still like to understand why that is, and where my lack of understanding lies.
    Well yes, the concept is "meter at" and "have a look at the monitor" at Iso =X - not really "set" Iso=X. But there is a logic to metering, like "those bushes should be two stops under, the window one stop over" and you would need to build that kind of logic around a base ISO and chosen f-stop - ND grade equation. I agree with 800, but you can get away with up to 2000 if need be on MX.
    The more I look at this the more I see the answer I was looking for, I guess. Perhaps I am not as confused as I thought.
    Quote Originally Posted by radfilm View Post
    Based on my broadcasted RED footage, here are two links of some HD reels from two TV shows I shot with RED at based on 800 ASA.. I really do not see any noise.. and there was no noise reduction.
    So for me I will stay exposing the camera the way I have all along.
    https://vimeo.com/37026176
    https://vimeo.com/37786881
    Regards,
    Dana Gonzales
    www.danagonzales.com
    Dana, this is absolutely gorgeous work! I'll have to experiment with ISO 800. One question though, in the Southland footage, at 1:26, am I seeing some blackpoint clipping in the flare? I didnt know the RED's had this issue... if thats what it is..
    Beautiful work regardless...
    Adrian
    Dec 2009
    Montreal
    Glad if I was of any help.
    Junior Member
    May 2012
    I'm hoping this cop reel wasn't shot on scarlet. this stuff looked bad in my humble opinion. sorry
    Jul 2009
    Quote Originally Posted by Tom Gray View Post
    Lol. Do you mean the Southland reel?
    Well, style and taste are equally subjective and, taken out of context it can be difficult to understand fully how a chosen style serves the narrative.
    That reel speaks directly to the OP's topic. Here is footage that pushes the limits of the camera's range successfully, at 800 ISO. It employs a reality tv kind of look but does it with a deft hand. These guys are obviously in complete control. For example: He's got crazy low exposure levels in there but still what needs to be seen is exposed adequately, with no noise. He talked about wide dynamic range, but also explores extremely contrasty images on the reel, and they work.
    Norway
    One very big difference between the two (which is there for a good reason) is that the default gamma on R1 is RedGamma, but on the Scarlet/Epic is RedGamma3
    redgamma is much harder in the top and bottom, which by default forces the "acceptable" lowest exposures a bit up (give them a bit more light when lighting the set) which again gives more latitude in the practical use of the lowlights, while Scarlet/Epic goes "deeper". The same happens in the top.,
    On R1 you are kind of "forced by the preview" to expose a bit safer to avoid the extremes. The Scarlet/epic allows for much more in the extremes, but of course there is noise down there too...
    In the top stops, the Scarlet/Epic really excells over the R1s I have seen, at least...
    Life is good. So is RED...
    http://youtu.be/mhFB1CMzQBM
    http://bit.ly/mCwcoN
    Twitter: gunleik
    Norway
    To follow up...
    If you want to emulate the R1s blacks on an scarlet, leave it at 800 and set the contrast to something like 0.5 (just ballparking here, not exact)
    A much better idea, IMHO - is to learn how to work with the extended latitude given by the Epic/Scarlet....
    Twitter: gunleik
    Just want to quickly add - I agree that images from the MX look better than the Scarlet. By some distance. EPIC looks better than both, but not by as much as you think. You can buy a used R1 kit for around 10-15k. If what you are interested in is just the final image there's no contest in my experience.
