Click here to go to the first RED TEAM post in this thread.   Thread: REDray Projector..
Page 24 of 35 FirstFirst ... 1420212223242526272834 ... LastLast
Results 231 to 240 of 347
  1. #231
    Jan 2008
    Quote Originally Posted by Stuart English View Post
    Eh ?
    That was an easy one Stuart, written in a language we are familiar with. What was your last name? ;)
    "The basic projector is a complex configuration of a beast in the way it is setup, and not conducive to cheap mass production?"
    The design of the upgradable projector over many parts and display mechanism, makes it difficult to mass produce as cheaply as a all in one 15 foot unit using a cheap display engine setup? Cheap production being in the $2k range.
    Luv stumping engineers with English! ;)
    Reputation is something the unwise apply.
    But integrity is what the wise apply.
  2.   Click here to go to the next RED TEAM post in this thread.
  #232
    Red Team Stuart English's Avatar
    Irvine, Ca
    Quote Originally Posted by Wayne Morellini View Post
    ... The design of the upgradable projector over many parts and display mechanism, makes it difficult to mass produce as cheaply as a all in one 15 foot unit using a cheap display engine setup? ...
    O.K, just wanted to clarify what your opinion was there.
    Workflow Wizard
  3.   Click here to go to the next RED TEAM post in this thread.
  #233
    Irvine, Ca
    Quote Originally Posted by Patrick Chong View Post
    You guys should reach out to IMAX, seems their laser system is a little behind...
    Workflow Wizard
    Jan 2008
    Another Eh? So by that comment can I assume that you will only grade on a CRT rather than on a LCD or Plasma or DCI projector ?
    Hmm, I am interested too. LCOS, have reached hundreds of frames of sequential color ages ago, and blue phase LCD can go much high, and I do not know about Los versions of that. However, it has to be, more or less, stable activity at the laser energy input, so a clear 100% on to off, off to on, or anything I between, what is the slowest refresh rate? Going onto another issue Stuart, what is the maximum contrast ratio, and black level on a max lit Lcos? What is the life expectency of the lcos, without performance degregation that would shift relative intensity of any pixel levels by more than 1024th (adding an error of one pixel level on a wide dynamic range). To be fair, it might not be an issue until more than 512th, an error of 256th, how long would that take? Conventional LCD projection systems are notorious for going off.
    But, he might also refer to just the time delay between the live video signal being sent and the frame being rendered on screen. I can imagine if there is time delay in camera transmission, computer reception and processing of image data and transmission and projection, then it might also add up to something substantial (btw, happy end of April day over there :-) ) .
    Jan 2008
    Don't need a speculative opinion there Stuart, if you spill those little red jumping beans :-)
    So I guess This is the Projector from HDI3d. Since that Companys website is offline.
    You can test latency of a projector
    http://www.avsforum.com/avs-vb/showthread.php?t=1377652
    Didn't want to produce an eh here :)
    No, I rather use LCD's or plasmas, and the latency for them are quite workable. Just wanted to know a little about latency for editing because it can slip the video out of sync if you aren't getting the audio out of the projector (like when using a mixing table)
  #238
    Irvine, Ca
    Well for any digital display device (not an analog system such as CRT) you can assume 1 or 2 frames of processing.
    Which is why you slip the audio on the playback device - or feed through an audio delay unit - to compensate for that.
    Workflow Wizard
    Quote Originally Posted by Aaron Fritz View Post
    Huh? The HD-I3D is made by Bernelli (who's site is not offline, works just fine here). And it's a 1080p projector aimed at upper mid-range home theatre installations, it has built in YouTube and Netflix as well as the ability to directly connect your iPod.
    Maybe I misunderstood what you're commenting on, but it just seemed really out of place...
    - Jeff Kilgroe
    Different hyphen placement. There was a company called HDI that was doing a laser-based projector.
