Click here to go to the first RED TEAM post in this thread.   Thread: Leica M Mount
Page 5 of 8 FirstFirst 12345678 LastLast
Results 41 to 50 of 76
  1. #41
    Quote Originally Posted by Jarred Land View Post
    Will be but a quick way to verify is if your M lens has a deep protruding rear element, it's probably going to be a problem. It mostly happens on the wides though.. and as incredibly fantastic as the wide M lenses are, they don't work as well as they should on digital sensors.
    Is there going to be any way in the future to use the wides?
    REDucation 005
    Scarlet-X #00600
    Braunschweig, Germany
    No, they will stay sub-par. This has to do with the different reflection and angle tolerance of digital sensors and film emulsion.
    For wide I'd get something modern…
    Regards,
    Uli
    My Red is called Vertov after a Russian avantgarde filmmaker, a pioneer in modern cinematography, a true revolutionary who later suffered under Stalin's bureaucracy.
    Senior Member Josh Beadle's Avatar
    Sep 2011
    SoCali
    That's what a UP 8R is for
    Josh
    Epic-M 1388 aka "Black Sheep"
    ATV FamFun
    It's not your camera's fault:
    http://www.youtube.com/watch?v=jJm2EGNIod0&feature=related
    "Your first 10,000 photographs are your worst"
    Henri Cartier-Bresson
    Senior Member KETCH ROSSi's Avatar
    Jan 2007
    ITALY
    Josh I hope you did preorder the Leica mount for your Noctilux .95... ;)
    KETCH ROSSi | EPIC-M DRAGON M8
    Producer | Director | DoP |
    *CinePhotographer
    __________________________________________________
    *Registered Trademark of RED DIGITAL CINEMA
    Aug 2007
    Quote Originally Posted by Uli Plank View Post
    Uli, is this in response to my question to Jarred re: Leica R glass?
    M
    Sep 2011
    SoCali
    Quote Originally Posted by KETCH ROSSi View Post
    . . . a couple hours before you . . . still would bet on you getting it first by a long shot my friend. No worries from me - no one supports the Brand better than you
    Josh
    ATV FamFun
    Jan 2007
    ITALY
    Quote Originally Posted by Josh Beadle View Post
    He he, thanks Josh, I do the best I can to share with the community, but I hope they'll go out in larger numbers so that we all get it at the same time.
    Even so I still am pretty sure no one will capture the kind of footage I got lined up for it, in my Movie scenes in 3D... ;)
    *CinePhotographer
    I think the problems the wider M mount lenses have with digital sensors are being overstated.
    Recording in RED's RAW format and being able to convert the R3D files into RAW still-image sequences allows the images to be corrected to a very high degree.
    Here's a basic test done with the Voigtlander 12 & 21mm M mount lenses - http://www.youtube.com/watch?v=fYVqu...ature=youtu.be
    In these examples, 'Corner Fix' was used to adjust luminance and chromacity values, in order to reduce the off-colour vignetting, then Contrast and Gain was adjusted in After Effects and/or Premiere Pro to adjust the overall look. The simple 'fixes' applied to these shots might not be perfect or complete, but with the full range of RAW image correction tools people have available to them I'd be surprised if it wasn't possible to get better looking results.
    IMO image quality concerns alone shouldn't be used as a justification for not modifying the camera's to accommodate the use of the wider M mount lenses.
    Here's a list of M mount lenses that can't currently be used (unmodified) on Epic/Scarlets, but which would be made available for use with a redesigned OLPF port -
    Zeiss
    Super Wide Angle 15mm f/2.8 Distagon T* ZM
    Super Wide Angle 18mm f/4 Distagon T* ZM (Black & Silver)
    Super Wide Angle 21mm f/4.5 C Biogon T* ZM (Black & Silver)
    Super Wide Angle 21mm f/2.8 Biogon T* ZM (Black & Silver)
    Wide Angle 25mm f/2.8 Biogon T* ZM
    Wide Angle 28mm f/2.8 Biogon T* ZM (Black & Silver)
    Wide Angle 35mm f/2.8 C Biogon T* ZM (Black & Silver)
    Wide Angle 35mm f/2 Biogon T* ZM (Black & Silver)
    Leica
    21mm f/1.4 Summilux-M
    24mm f/1.4 Summilux-M
    35mm f/1.4 Summilux-M
    28mm f/2.0 Summicron-M
    35mm f/2.0 Summicron-M (Black & Chrome)
    28mm f/2.8 Elmarit-M
    18mm f/3.8 Super-Elmar-M
    21mm f/3.4 Super-Elmar-M ASPH
    24mm f/3.8 Elmar M
    16-18-21mm f/4 Tri-Elmar-M
    Voigtlander
    UltraWide Heliar 12mm f/5.6
    SuperWide Heliar 15mm f/4.5
    Color-Skopar 21mm f/4.0
    Color-Skopar 25mm f/4.0
    Ultron 28mm f/2.0
    Color-Skopar Pan 35mm f/2.5
    Sep 2011
    SoCali
    Thank you for the efforts and post!! Let's take a Sawzall to that sensor port and ship us some Leica mounts!
    Josh
    ATV FamFun
    No worries, attached a picture (thanks Pawel) to show where to start cutting.
    Seriously though, I could be wrong, but it looks like what the OLPF port screws into (the sensor mount seen in the other picture) needs to be widened too, not just the OLPF port itself.
    Not sure if that degree of modification can be justified, or that RED's making and selling an M mount necessarily obligates them to modify their camera's to make the full range of M mount lenses fit.
    Maybe there are other reasons (beyond fitting wider M mount lenses) why it would be beneficial. Certainly can't see RED offering to replace that/those part/s before the Dragon sensor upgrades though (when the camera's have to be pulled to bits anyway).
