Click here to go to the first RED TEAM post in this thread.   Thread: Is the RED Rocket compatible with all RED formats?
Results 1 to 4 of 4
  1. #1 Is the RED Rocket compatible with all RED formats?
    Junior Member
    Dec 2010
    I have a Nehalem MacPro running Snow Leopard with a RED Rocket installed. I am using RED Cine X build 506. I don't do many RED transcodes but when I do it becomes a lifesaver.
    I have found recently that the RED Rocket works with some media and not others. Here's the latest batch...
    3072x1728, 25fps, RED One, Mysterium X, REDCode 9:1 = Fast as lightning.
    2048x1080, 25fps, Epic M, Mysterium X, REDCode 12:1 = Error decoding frames, spinning wheel of death.
    As soon as I turn off the RED Rocket it transcodes normally (but obviously without the speed of the Rocket).
    Was there a firmware update to work with the Epic? Are only certain frame sizes supported? Am I being stupid? Is there any other info I need to give you?
    Thanks for any help.
    Moderator Martin Weiss's Avatar
    Mar 2008
    mostly Norway
    The latest built is 1.4.19. If you have an older version, I would suggest to try an update and see if the problem persists.
    https://www.red.com/downloads/4f56854d6261f95a57000669
    Norway
    Quote Originally Posted by Gary Askham View Post
    Sounds vaguely familiar... When started the symptoms?
    Life is good. So is RED...
    http://youtu.be/mhFB1CMzQBM
    http://bit.ly/mCwcoN
    Twitter: gunleik
  4.   This is the last RED TEAM post in this thread.   #4
    Bender Matthew Yaeger's Avatar
    Sep 2009
    Southern California
    Please upgrade to RedCine-X Pro, many improvements have been made including format support.
    https://www.red.com/downloads?release=beta
