Thread: Epic M and X Data Sheet
Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 44
  1. #11
    Well yes, that's on the extreme side of things :) But not totally out of whack for natural wildlife shooters who overcrank on eagles and whatnot.
    phfx.com IMDB
    Scarlet-X #316 "Skully"
    Added:
    Camera Temperature Guidelines and Warnings
    Quote Originally Posted by Dave Winder View Post
    The camera will shut down for temperature reasons. Below is the behavior you should get when reaching high temperatures.
    At 72c the temperature display will turn yellow
    At 74c it turns orange
    At 75c the user speed is overridden and fan goes to max speed. Even if recording.
    At 76c the temp display will turn red. Although max fan speed usually prevents getting there.
    At 77c if you are recording, the record will be stopped
    At 83c the camera will shutdown
    phfx.com IMDB
    Oct 2011
    Los Angeles, CA
    Hey Phil, I'd like to propose a minor modification to the max frame rates table.
    If you dial it in manually you can shoot 303 FPS at 2K, 121 FPS at 5K WS. Maybe that's nit picky and could confuse people, so I'll leave it at your discretion as to whether or not it's worth adding.
    Overall though it's great guide to refer to, I don't know how I missed it when it first popped up on the forum.
    Epic-M #1364
    Thanks Peter. I don't own an Epic (yet) and went with what I last knew was good info. After the newest firmware update I'll update the chart with new frame rates and other thingies.
    phfx.com IMDB
    *update*
    New firmware brings new frame rates. Added this "format key" to the first post:
    Red Format Key
    This is a key to the different Red capture formats. It contains the format name, max fps, resolution, and aspect ratio. I've included both Epic and Scarlet information on the same key; hopefully useful to those using Epic and Scarlet in A/B cam situations.
    - Download 2k Version - Download 5k Version
    I have also updated the Data Sheets to include the new frame rates and info.
    phfx.com IMDB
    Senior Member Jens Jakob Thorsen's Avatar
    Denmark
    I think the 5K HD res is wrong...It must be 4800x2700 and you have 2K HD and 2 K WS confused...Maybe you should take an extra look and see if there are other mistakes ;-)
    Thanks for the list, it is helpfull.
    Jens Jakob Thorsen D.F.F.
    DOP
    Denmark
    www.jensjakob.com
    mail@jensjakob.com
    Epic #479
    Yep, got the word there were a few errors. I've fixed those now. Thanks.
    phfx.com IMDB
    Jun 2009
    Los Angeles, CA, USA, Earth, Solar System, Milky Way
    I'm confused by the frame rates in the 2 data sheets. There's discrepancies. For example, the top one says 4K HD is up to 160 fps, and the bottom one says only 120 fps. There's differences at 3K and 2K also. Did we lose fps capability in 3.2.8?
    Sorry about the confusion Mike. I've updated the data sheet with the correct information. There was no FPS loss in 3.2.8.
    phfx.com IMDB
    Senior Member Thomas Koch's Avatar
    Jan 2007
    Silicon Valley, CA
    What ever happened to 120fps at 5K? Wasn't that the spec? I know i've never done it, but I thought it was what was planned.
