Thread: Quick RED Compression Ratio Comparison
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1 Quick RED Compression Ratio Comparison
    Dec 2010
    Toronto
    Quick little test comparing 6:1, 12:1, and 18:1... I wanted to see how noticeable the differences would be at the delivery stage (generally compressed and 1080p, not 4k/RAW). Figured there would be some soon-to-be-Scarlet owners (or 32gig SSD owners) that would want to check it out in order to maximize their REDmags. I cover most of the details in the video's description.
    Must say I was pleasantly surprised seeing as how we're dealing with approximately ~3gigs/min vs. ~2gigs/min vs. ~1gig/min... Holds up extremely well in the grade, too. Granted there was tons of ambient ~5600k light, which definitely helps, but it's good to see that you aren't sacrificing too much quality whilst literally getting 3x the amount of recording time out of the same REDmag. It certainly doesn't seem to be 1/3rd the quality at the deliverable end (they all look pretty much the same, which I guess is to be expected when they end up being crammed into the same 10mbit h264 codec regardless of the source ratio, but still).
    Senior Member Nick Pasquariello's Avatar
    Dec 2010
    Providence, RI
    If anything, in post, I've noticed that a higher compression ratio = more visible noise. Perhaps the compression ratio needed is situationally dependent? Recording in a darker setting could mean you'll want to bump your compression ratio down?
    Icarus Rex Productions
    Scarlet #1798 "Ariadne"
    Hi Mike,
    Most of the frame is static. I bet you will see more of a difference if there is more motion as a greater percentage of the frame. I had done a quick test of a talking head set up and found 18-1 held up really well but also not much change per frame. Motion like a pan would probably show issues. Thanks for the test.
    William Dempsey
    Feb 2010
    Helsinki, Finland
    A windy wheat field in the rain is a brilliant go to for compression tests.
    Dec 2009
    Chatsworthless, CA
    Water and smoke are also good torture tests for compression issues. Another good one is a stadium shot, with lots of little teeny-tiny people in the grandstands. I've seen certain MPEG images just completely fall apart with motion artifacts and dropped frames with complex shots like that.
    www.cinesound.tv | location sound / post-production consultant
    Norway
    What used to be compression stressing for the R1, would be something like a shot in a forest with high contrast, tons of detail (leaves and branches) and some motion.
    The field and the stadium and smoke sounds good, too...
    Life is good. So is RED...
    http://youtu.be/mhFB1CMzQBM
    http://bit.ly/mCwcoN
    Twitter: gunleik
    Senior Member Nick Wernham's Avatar
    Oct 2011
    Toronto, ON
    You've gotta love the distillery district as a location though. Such an interesting place to shoot!
    C.E.O. of Wernham Entertainment Inc.
    Current Project(s):
    "Business Ethics" [Completed Short]
    "Public Service" [Short in Post]
    "No Stranger Than Love" [Feature in Pre-production]
    Co-Owner of Epic-X #3805 "Hentgen" & Scarlet-X #557 "Stieb"
    Mar 2011
    Toronto, ON Canada
    I remember the day they had a casting call for tall skinny dudes when they were shooting the concentration camp scene for the first X-men here. My friend got a part as an extra. Not sure why I didn't??? Oh yeah, I'm not white, tall, or skinny! Ha ha!
    ___________________________
    10 frame handles
    Vimeo
    Scarlet #329 "HAL"
    Braunschweig, Germany
    Quote Originally Posted by Gunleik Groven View Post
    Hi Gunleik,
    why do you think it needs motion? RED's compression is strictly Intra.
    Regards,
    Uli
    My Red is called Vertov after a Russian avantgarde filmmaker, a pioneer in modern cinematography, a true revolutionary who later suffered under Stalin's bureaucracy.
    Norway
    Quote Originally Posted by Uli Plank View Post
    Hi Gunleik,
    Sure! But with tons of small motion in leaves or grass or waves in the sea, the difference in compression between high-detail frames, used to be a stress test. Early on, you could even make the camera go down under such conditions, because it didn't handle them... :) (Looooooong time ago).
    I am in no way sure of this (!!!), but I have been wondering that as it is a VBR codec, sometimes the "next" frame could suffer if the "1st" was "hard" to get right...
    Haven't run these tests on Epic, and my guess is (again due to all the computing overhead apparantly available inside that box) that it won't be an issue at all! But yoy could trigger t at higher compressionratesm still... as the wavelet "evens out" stuff. Add motion, and that could differ from frame to frame...
    Maybe I should try! :)
    G
    (Just contemplating ways for breaking beauty...)
    Twitter: gunleik
