Thread: RED SCARLET & CANON c300
Page 1 of 7 12345 ... LastLast
Results 1 to 10 of 64
  1. #1 RED SCARLET & CANON c300
    Hello everyone and I need some help before a purchase. I had my mind and budget set on the Canon c300. Although Im still a little confused as why Canon didnt put 120fps in that camera for that price. I'm sure that all will chime in and blast them . After doing some research the SCARLET has intrigued me. Not so much the whole 2K,4K but rather the look and the 120fps at 1K I believe. What may not allow me to purchase this camera as its too customizable that would force me over the $16K budget . With a c300 I already own CANON & ZEISS glass, so all I need are just additional CF Cards. With the SCARLET I need all this other stuff that will drive me over my budget. I'm asking for some help as I my assumption maybe incorrect. Thanks to anyone in advance that can help.
    Senior Member Steve Sherrick's Avatar
    Boston
    Tough call. I'd add the Red One into the equation as well unless the bootup time and possibly the form factor are a problem for you. There are some full shooting packages that have listed in your budget range here on Reduser. 120fps at 2K.
    C300 is a good camera. If it does everything you need it to and you've done your own tests to prove that to yourself, then that's okay. I do think Scarlet is a better investment at this point, especially now that we know that it will qualify for Dragon upgrade. But if it's out of your price range, it may be a moot point. Either way, I'm sure you'll be okay. Both high quality cameras. What kind of projects do you do?
    Steve Sherrick
    Chief Collaborator
    Modern Vintage Media
    STEVESHERRICK.COM
    Local 600 DIT/Operator
    Sep 2011
    Resolution may not matter to you now, but it will once you start shooting 4k and the stuff at NAB and CES for 4k displays start hitting consumers. But let's assume for a moment that you really aren't interested in the Scarlets 4k resolution or upcoming upgrade to 6k Dragon sensor (Canon does not offer an upgrade path, btw).
    You said you were attracted to the Scarlet for the 120fps @1k. This isn't out yet (as far as I know, mine does not have it yet). I've shot 48fps @3k and with a high shutter speed, feel like I can get some good results using software like Twixtor to get even slower. Most of the time, you are never using high-speed/slo-mo. But if you are using it, I would not say the Scarlet is superior here (yet), but it isn't a negative either.
    You asked about price. Scarlet-X comes in an aluminum Canon Mount package with side handle, 2 REDvolt batteries, charger, 64GB SSD magazine, AC power, touch monitor and reader for $16,165. You don't need anything else to start shooting. You can use your Canon class and canon mount Zeiss glass right away. So, not sure why you feel you need to buy more to make it workable compared to a Canon C300.
    The big thing you might consider that the RED shoots RAW. Even if you don't care about the resolution, you can't underestimate the power and convenience of RAW footage. Its like asking a professional still photographer to going back and shooting JPEG instead of RAW....it simply won't do for most of their work.
    After the Dragon sensor announcement, I am SOOO glad I went Scarlet. In a year, I'll have 6k and high framerates that the competition won't be able to touch for another 3-4 years...just like they are struggling to catch up to 4k now.
    EDIT: If you just want great non-raw 1080p, it can be a tough call for some, but the perception that RED needs all this other equipment to shoot is something I disagree with.
    Senior Member Brian Pascale's Avatar
    Nov 2011
    Silver Spring, Maryland
    You can use your canon lenses on the Scarlet if you buy the canon mount. I don't believe that 120fps has been implemented yet. I bought a Scarlet, I think it is the better camera, but there is a larger learning curve, but also more flexibility. The greatest additional cost is the SSD for recording. And the Red Rocket for post, or you have to invest in a system that can handle 4k natively.
    Scarlet "Fever" Ti Canon Mount
    Brian Pascale
    Thank you Steve! I produce commercials, music videos, marketing videos, corporate, live events, shorts, etc. Unlike Canon RED has to have all of these things to function.
    Sep 2011
    I agree on the cost of media. It is more expensive, and you will probably end up needing to offload footage if you are doing a whole day shoot unless you buy more media.
    I don't use a RED rocket at home. I am running the last generation iMac to edit and am doing fine so far. Premier Pro works great with raw RED footage and can play back without a RED rocket, which is pretty amazing. Just wish Premiere had redcolor3 supported already.
    Mark,
    thats great news and thank you for clearing it up for me. So the SCARLET doesn't shoot 120fps @1K? How much time will I get out of those cards? I don't see shooting at 2K or 4K right now for the type of work that I do, but it LOOKS NICE!
    Mar 2011
    Toronto, ON Canada
    Once you get a taste of working in RAW and 4K, there is no going back my friend.....
    ___________________________
    10 frame handles
    Vimeo
    EPIC-X "SHAI"
    Will the SCARLET work with the AJA KI PRO-mini or the newly announced KI PRO QUAD? Seems to me that could be an awesome solution.
    Senior Member Noel R.'s Avatar
    Sep 2011
    North Bay, CA
    Realistically I think you need more than 16K for an operational Scarlet. One 64 Gb SSD will only get you 25 minutes worth of footage. You will need at least one more SSD so you can dump your footage in between takes. You will also need more battery life. REDVOLTs have a span of about 25-30 min. I believe that package comes with two, and they take too long to charge in between takes so that won't work. I think the Scarlet is the better camera with the exception of low light performance. You can also upgrade it. Don't buy it because it can do 120 fps at 1K. 1K doesn't look that great and has an enormous crop factor. You probably wouldn't use it too often.
