Thread: Fine Netting?
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1 Fine Netting?
    Senior Member James McLellan's Avatar
    Nov 2009
    Center of Jetmania
    Hi,
    I'm wondering if there is a material for netting off a window that will bring it down a few stops and move it towards tungsten light balance. Like a fine gold netting or something. Maybe 15' x 20' in size?
    Does something like this exist?
    Jul 2009
    Why netting? Will gel not work for you for some reason?
    you can buy single and double netting as yardage at most mathews equipment dealers.. you need gell to correct color balance.. you can buy Rosco and Lee combination ND and 85 if I remember correctly...
    REDuser Sponsor Andy Jarosz's Avatar
    May 2009
    Chicago
    You can attach rolls of gel on a window simply by wetting the window or gel first, and it will stick.
    If you really want net, the material is called bobbinet.
    AC and owner of MadlyFins, LLC
    Chicago, IL
    708.420.2639
    andy@andyfilms.net
    www.madlyfins.com
    Senior Member Ken Willinger's Avatar
    Jan 2007
    Boston, MA USA
    You might try some Rosco Scrim. Works a charm. Then add some 85 behind it.
    Ken Willinger S.O.C.
    http://kenwillinger.com/
    Senior Member sergio arguello's Avatar
    Aug 2008
    Buenos Aires,Argentina Los Angeles
    thats what hdrx is for...the new improved netting..and bring your interior lights to blue and tadaaa its warmer outside
    sergio Arguello:
    Epic-M 459,Epic-X 751
    RED Rocket™™™
    sergioarguello.net
    Nov 2009
    Center of Jetmania
    I was just wondering if there was a net that could do both in one swoop. Just seems like it would be a real sweet deal, no cutting no fuss, but it looks like there isn't anything out there is there.
    IIRC, there ar some rental houses which have "hard" gells... like giant filters in pre made sizes for window.. contact your local grip house..
    Quote Originally Posted by James McLellan View Post
    Hi,
    They make ND.3 .6 and .9 /CTO Gels.
    Cuts + Converts to tungsten
    Cinegel #3405: Roscosun 85N3
    Combines the effect of the 85 and N.3 filters. Extra-wide 60 in. Optically clear. (Transmission = 33%).
    http://www.rosco.com/us/filters/cine...displayType=13
    Jul 2009
    I think you mean to say it converts daylight to tungsten.
    Quote Originally Posted by Brandon J. Garcia View Post
    Cuts + Converts to daylight
