Hi everyone,
as mentioned above, my sidehandle causes freezes, display on it doesnt work and the wheel with its set button doesnt work. Everything else works fine. No matter if I use AC Power or Global Media Batterys.
Though it worked for 20 minutes, but after I ejected my SSDs via Menu and pulled it out I pushed the Rec button on the sidehandle and it started to record??!! while Timecode turned blue and fans slowed as if in rec mode.
I filled a ticked was told that I may have void warranty because of use of GLobal Media Batterys and that I should try Red Bricks???
I also tried reinstall 3.0 and restore settings.
How in hell does Red Bricks repair a unit or how do they not equal as the original Red AC Power Adaptor?
I'm very confused. By the way, the unit already had some scratches on the surface and looked used.
Did someone had the same problem and if so, how did they manage to solve this?
