Thread: Black Shading Calibration has caused sensor problems!!
Results 1 to 10 of 10
  1. #1 Black Shading Calibration has caused sensor problems!!
    Junior Member
    Jan 2012
    Hi Guys,
    Has anyone experienced any problems after performing a black shade calibration?
    I performed a calibration and after successfully completing the sensor area in the monitor started to flicker with horizontal lines. Then half of the screen became covered with a pink block (photo attached).
    I decided to try and do a system reboot and after this the monitor did not come on.
    I left the camera unplugged for serval minutes, the monitor came back on, but still the sensor area is covered up. When I attach a lens, the image that I can see appears like i have the camera settings at a very low shutter speed as it appears blurry or just generally lagged.
    Any advice of general practice to how I could resolve this issue?
    I have submitted a ticket to Red.
    Many thanks,
    Phil
    Junior Member
    Jan 2012
    Just powered it back up and it came up with this error message:
    ERROR: 0x0000001D
    Photo Attached.
    Senior Member Terry VerHaar's Avatar
    Sep 2009
    Silicon Valley, CA
    Have you contacted tech support at RED? They tend to be pretty responsive to these things.
    Nov 2011
    South Bay Area, CA
    Quick search of the forum, This thread talks about having the same error code as you. Probably a good idea to get the ball rolling and contact RED support. EDIT: Terry beat me to it!
    Did you have anything else besides LCD and side handle attached to the camera during the black shade?
    Alexander Thomson
    REDucated June 2012
    DP for Perpetual Pictures.
    I've had similar problems where a third of the frame would be pink and also some random frame in a clip would have it, but just one single frame in random places during a clip.
    I just updated firmware to 3.0.6 so hopefully that will solve everything.
    Clint Childers
    Red#846
    Junior Member
    Jan 2012
    I contacted them through this link:
    http://www.red.com/contact_us
    But I'm UK based, so all the Red Europe offices are closed at the moment. I've submitted a technical support ticket through the link as soon as it happened but no reply yet.
    CLINT, has the beta firmware update helped your issue? Did you ever get an error message like I did?
    ERROR: 0X0000001D
    Thanks,
    Phil
    Junior Member
    Jan 2012
    Quote Originally Posted by Alexander Thomson View Post
    Hi Alex,
    Yes i found this thread when i got the error message pop up.
    All I had connected was SSD, Monitor, Side handle and mains power.
    Junior Member
    Jan 2012
    I just completed a roll back after system restore to the previous firmware V2.0.5 and now the camera doesn't even switch back on!!
    Senior Member Dave Weber's Avatar
    May 2007
    Orange County, CA
    Phil,
    Was there an SSD in the camera when you did the black shade? In your first photo it doesn't show one being mounted in camera. If i remember right a formatted SSD needs to be in the camera.
    Dave Weber
    MX 801 "Lucky"
    EPIC-X 268 "THE X"
    www.imaginationwerks.com
    www.atomic13.com
    "You can't depend on your Eyes when your Imagination is out of Focus"
    Mark Twain
    Junior Member
    Jan 2012
    Hi Dave,
    Yes an SSD was in the camera. These photos were taken after the calibration had completed. I tried taking out the SSD and then theside handle to see if it would help fix the problem.
    Its now with Red Europe at Pinewood. From the error code I sent, they say that it could be something to do with the communication board.
    Hopefully find out tomorrow with the log I sent them and with the camera in their possession.
    I'll post back here when I find out any new information.
Tags for this Thread
View Tag Cloud
