Is there a D- tap on the Pro i/o???
No. The power output is 4-pin Lemo.
So how do run a wireless ff and a sdi monitor with a d tap to 4 pin XLR cable? Hmmmm so only
1 12v Lemo like on the Red 1, not 2
There are several options, first you can use the dtap on the battery plate like most cameras utilize. You can have a distro box made, or get a dtap distro box from b&H and you can have a lemo cable made to power your FF or monitor.
Thanks, Trying to get away from the Batt plate and make the move to all redvolts especially for steadicam. So they make a lemo to D Tap Breakout. I've never seen that.....been looking all over the internets too.
Now does the +1 Module adapter have a D tap?
No, you would have to have one built for you.
But not sure if the revolts are suitable for powering external devices.
So what the 4pin lemo aux is really only for is a W FF systems ... I guess RED really wants us to buy the 9" touch screen and not use SDI monitors on Camera
I am not sure you will get enough power out the lemo to power wireless FFs ?
