Thread: Olympus ME51s Scratch Mic for Red Scarlet or Epic - tested & works!
Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 58
  1. #1 Olympus ME51s Scratch Mic for Red Scarlet or Epic - tested & works!
    Senior Member Jon Carr's Avatar
    Aug 2009
    NYC
    how is it powered? I thought phantom power was not enabled?
    Dp Reel
    http://www.visualcinema.com/reels/
    Rentals in NYC
    http://www.visualcinema.com/rentals/cameras/
    EPIC-X #5359 GNX (soon to be Dragon)
    Canon & PL mount, Canon 16-35, 24-70, 70-200, Rokinon 24mm, 35mm, 85mm, & everything you need to shoot RED!
    It's REDcode or no code...
    I'm using firmware 3.0.0 (no phantom power enabled on this build) so it doesn't need phantom power to work. No battery power needed. It just works! =)
    Mar 2011
    Toronto, ON Canada
    Ordered. Thanks for info!
    ___________________________
    10 frame handles
    Vimeo
    Scarlet #329 "HAL"
    Senior Member Eli Jarra's Avatar
    Thanks Tonaci...great find, and just in time too!!!
    ---T H I N K P I C T U R E S--- http://vimeo.com/thinkpictures --- twitter: @powrslave ---
    Senior Member Malvin Ng's Avatar
    Apr 2011
    Thanks for the information Tonaci :)
    Moderator Martin Weiss's Avatar
    Mar 2008
    mostly Norway
    The only problem I would have with those, is that they look like real easy to snap off.
    I hear ya on that Martin.
    With the placement being under the lens, it seems like it is mounted in a spot that is pretty hard to get to, so unlikely (at least to me) that it can be accidentally hit to snap off.
    Regardless, i recommend using the extension cable it comes with to get it away from being placed right next to the fan.
  10. #10
    Senior Member Ryan De Franco's Avatar
    Oct 2010
    Brooklyn, NY
    Perfect. But with the extension cord, you're left with just the lav clip to attach it to the camera... any clever rigging advice?
    NEVERMIND. Just saw the price. You could rig this thing with titanium allen screws and it would still be worth it. Ordered!
    The more opinions you have, the less you see.
    Wim Wenders
