This is basically some super low weight asseories that is custom built to work with the clutch and they basically a nice adjustable skater dolly included in your clutch.
Check these links to see how super smooth and how solid this setup actually is. The clip is done with no post stabilization or such.
http://www.syndicate.se/Files/~usr/f...nd%20dices.MOV
http://www.syndicate.se/Files/~usr/f...er-960x450.mov
http://www.syndicate.se/Files/~usr/f...201024x576.mov
since the clutch handles are on ball joints the front wheels can be adjusted to any angle, Just as the "back wheel" that also can be adjusted around two axises using the back support and letting the wheel mount swivel around the included 19mm carbon rod.
http://www.syndicate.se/Files/~usr/f...nt%20setup.MOV
Price is now lower since we optimized the tooling.
Clutch setup: 250USD + shipping
including:
2 x front wheel handles
1x 19mm wheel clamp
Back support 19mm rod clamp.
3 wheels (choose between small black or big green)
Screws for the above.
So email: info at syndicate dot se to order, expect 5 workdays delivery time.
http://www.syndicate.se/Files/~usr/f...W%20ACTION.MOV
So if you have a clutch and what to pimp it with wheels just send a pm.
