Click here to go to the first RED TEAM post in this thread.   Thread: May Product Delivery Update
Page 13 of 28 FirstFirst ... 39101112131415161723 ... LastLast
Results 121 to 130 of 271
  1. #121
    Senior Member Joel Arvidsson's Avatar
    Nov 2008
    Sweden
    Plus one to audio playback? Also I looking forward to activate the gyro.
    Does 5k hd, 3k hd mean 16:9?
    Is quad hd to close to 4k so it was no point to make a 4k 16:9?
    Scarlet #00549 Elmer
    Senior Member Jeff Whitehurst's Avatar
    Nov 2011
    Hawaii and all over the Western US
    * Added Gyro support
    Jarred, since we'll be working with it enabled in a few days, can you placate us with a bit of info on the "Gyro support" feature and what exactly that is?
    Cheers, that's a bunch of hard work represented in this list of updates :)
    Jeff
    Jeff Whitehurst Scarlet-X #1177 "Pearl"
    www.jeffwhitehurst.com
    www.kipukafilms.com
    Nothing Happens Until Something Moves
    - Albert Einstein
    Feb 2010
    Toronto
    Quote Originally Posted by Jeff Whitehurst View Post
    Jeff
    Yeah I'm kind of stymied on this one...
    Can't believe I get paid to do this.
    If I don't own it I rent it...
    Senior Member Josh Negrin's Avatar
    Oct 2008
    I may be completely off base here, but I think the gyro support is meta data that helps in stabilizing footage later?
    Josh Negrin
    All your base are belong to us
    IMDB page
    Senior Member Paul Nordin's Avatar
    Feb 2007
    Emeryville, CA
    So far thats whats been implied by Jarred
    __________________________
    EMB Studios
    Emeryville, CA
    www.EMBStudios.com
    Epic-M 567
    Mar 2011
    Toronto, ON Canada
    The Epic will have the ability to record gyro and accelerometer info in the metadata which will be very handy in 3D tracking.
    Quote Originally Posted by Glen Powell View Post
    ___________________________
    10 frame handles
    Vimeo
    EPIC-X "SHAI"
  7. #127 Give them an inch...
    San Diego, CA
    Quote Originally Posted by Jaakko Rinne View Post
    Any chance of 2.5K HD in the future to get a usable 50fps out of the Scarlet?
    I suggested about a year ago that RED offer a resolution option for Epic that gives us enough pixels for a clean 1080P decode/scale (I would think around 1,280 vertical), but no more, to maximize the "clean" FPS rate. For some projects its essentially invisible when you take a 1,024 vertical pixel image and up-rez it into a 1080 timeline, but not always, especially if there is a bit more noise in the oft used 2K-WS, 300fps image to start with. 3K is the usual compromise, but at 150fps its not much more over crank than 4KHD at 120fps so I rarely use it.
    Perhaps a 1,280 by 2,560 2:1 (2.5K) frame could get up to 200FPS+ and fill the gap between 4K@120 and 2K-WS@300? With the higher data rate RedMags in the pipeline, this could lead to lower compression 1080 output with no up-rezzing at frame rates enough higher than 120 to expand creative options...
    Or, maybe I am suggesting this so Rob doesn't get any extra time off after this build ships ,-)
    Cheers - #19
    Senior Member Patrik Kisucky's Avatar
    Sep 2010
    Boston, Ma
    Great, Thanks for the info. 120 fps sounds great. Let's see, how is the image going to hold up.
    Scarlet-X, #899, "Precious"
    ParadigmsPictures.com
    VideographerforWedding.com
    Jul 2010
    Stamford CT
    So stoked out! Thanks
  10.   Click here to go to the next RED TEAM post in this thread.
  #130
    2.5k sounds interesting.. will add it to the list.
    Anamorphic is not out of the question for Scarlet..
    Gyro support means we have turned on the sensors... info will be sent to metadata for various programs to work with.. all that work obviously needs to be done as we work with 3rd paries.
