Thread: VIEWFINDER IMAGE GOOD. FOOTAGE OVER EXPOSED. WHY ??
Results 1 to 7 of 7
  1. #1 VIEWFINDER IMAGE GOOD. FOOTAGE OVER EXPOSED. WHY ??
    Senior Member George D.'s Avatar
    Oct 2008
    N. California, USA
    I have run into a problem that I'm sure has an easy solution. I just can't figure out what it is.
    We just bought a used second Red-One and, unlike the first one we got directly from Red, when the image in the original EVF and the external monitor appears to be exposed good, the exposure bar at the bottom of the viewfinder reads in the yellow and red. When the bar is in the green, as it's supposed to be, the image is so dark we can hardly see it.
    Later when the footage is placed in RedCineX it is severely overexposed.
    It is obvious, that there is a setting "somewhere" that controls the intensity and brightness of the viewfinder and monitor, but I can't find it.
    Would someone be kind enough to walk me through the steps necessary to correct this problem?
    Thanks for your time.
    Senior Member Nate Clapp's Avatar
    Sep 2007
    Wash, DC
    Could you be viewing "raw" on camera and only in redcine seeing it with metadata? If you set Asa /ISO In Redcine at 320 and it looks ok then likely you were in "raw" mode when you were shooting.
    Oct 2008
    N. California, USA
    Quote Originally Posted by Nate Clapp View Post
    It looks like you may be correct. I put the ISO in RedCineX on 320 and the exposure if fine.
    How do I change it OUT of the RAW mode?
    Thanks for your help.
    Sep 2007
    Wash, DC
    Likey it is a programmed feature of one of the assignable buttons on he camera. There are 3 buttons on eyepiece, two of which are programmable, two on body and if memory serves, one on the LCD. I would first push each of those to see if they toggle you in/out of "Raw" mode.
    Raw mode is also indicated by a small indicator in eyepiece or LCD but I can't remember what it is (it is not the big "Raw" on lower left. That's always there).
    All my mental pictures of RED one have atrophied since I sold mine or I would tell you how to directly go into menu and turn it off.
    Oct 2008
    N. California, USA
    If anyone can tell me how to do that via the menu, I'd really prefer doing it that way.
    Thanks.
    RAW versus REDColor is in the VIEW menu.
    Stephen
    RED One M-X "Lewis" (#791)
    First feature film, Works in Progress, out on DVD (Vanguard Cinema).
    Second feature film, Terminal, now in post-production in Kansas City and scheduled for a late 2013 release.
    Third feature film, Dust, currently in pre-production and scheduled for production during summer 2014.
    Oct 2008
    N. California, USA
    Quote Originally Posted by Stephen Pruitt View Post
    Stephen
    Thank you very, very much Stephen.
    That did it.
    Be good.
