Thread: THE beast 32 core HACKINTOSH is ready.....CS6 vs REDROCKET
Page 4 of 10 FirstFirst 12345678 ... LastLast
Results 31 to 40 of 92
  1. #31
    Senior Member luigivaltulini's Avatar
    Oct 2009
    Switzerland- LUGANO
    Quote Originally Posted by luigivaltulini View Post
    the beast has been tamed ...
    many hours and much suffering, it works now.
    sandy SUPERMICRO mainboard X9DRi-LN4F+ with e2690 dual cpu xeon....
    osx 10.7.3, 11.3.0 kernel with support for ivy bridge,
    32 cores with steep speed enabled.----------------------- not avaiable SPEED sTEEP....
    Support for 4 gpu tested. for now in testing fx1800 and 9800gx.
    support should take 2 gtx 590. In the coming days we will test
    4 port lan enabled.
    Joe Safai is doing some testing over the next few days will keep you updated.
    If anyone is interested in some tests with R3D files happy to oblige.
    CS6 5k for now all in real time full frame at full resolution ..... without redrocket.
    Geekbech above 30000 points.
    Thanks to Joe for your patience.
    Sorry, but under test.. speed steep not workk...
    only solution would be to extract all of the table are p-and c-state and put it in ssd.aml. with several steep, making patches to various kext and hope it works. Working too long ..
    Especially in remote desktop ...
    For now, the only quick solution would be to disable EIST and overclock the mainboard. Unfortunately not possible on supermicro .. I do not know what it's worth.
    This machine with 2 gtx 580 or gtx 590 is not compromised, especially for someone like me who needs ProRes at this time.
    And the boys will remember that before this without redrocket cs6 was very long and rendering. As you put movies from 10min to 1 hour was almost always rendered.
    Now with this card and cs6 we are close to real time ...
    only need to be happy.
    Up to that time. up and that I 'll need ProRes. I do not go on windows. It makes me sick and you have to be real, most of the people, editors, filmmakers, videomakers, and and and ... working on ProRes. both for import and export. And now that you can export from cs6 4k with no errors and too good. Delivery 4k proress 4444 or 422 to be managed with the new cs6.
    But have you tried to edit a 4K 422 on the timeline? I remain shocked every time is extremely fluid on my 8-core, let alone on this beast ...
    Perhaps I set too much on this ..
    Sorry for the outburst.
    Luigi
    TELEVISION BROADCAST SWITZERLAND
    www.rsi.ch
    Color Correction DAVINCI Resolve/Digital Workflow/Red Camera Rental
    EPIC #599 and #668
    SITE
    www.cine5k.ch
    Does Resolve not support ProRes in a next update on windows?
    Mar 2009
    Kolkata, India
    Most Windows software can encode ProRes by using Debugmode Frameserver > FFMBC (including 4444).
    Ironically, the reverse engineered FFmpeg ProRes encoder is significantly faster than Apple's own ProRes encoder on OS X.
    Of course, if you require ProRes on a daily basis, better stick to OS X as it is easier and natively supported in all apps.
    A Resolve Beta on Windows did include ProRes encoding for a short while, but it was removed quickly. Maybe they received a cease and desist from Apple. I think that is what is holding support in commercial software back, it is a pretty simple codec to reverse engineer. Filmmaster and Telestream do have ProRes encoding, as far as I know, perhaps licensed directly from Apple.
    Oct 2009
    Switzerland- LUGANO
    Quote Originally Posted by Subhadip Sen View Post
    Ciao Subhapin,
    of course, This is the point, I need ProRes in the day or the next day, working.
    It would exit REDCINE_x or CS6 directly to ProRes and not in the QuickTimeuncompressed and then convert it even in ProRes. Wasted time and wasted disk space.
    Yes I still have the Davinci version that does ProRes, but most of the time movies are corrupt, or start at half time and even those made at 120 fps will not work.
    In short, a disaster is impossible to work well, obviously for testing ok.
    Subhapin, the tests are fine, but when you're on set, I need stability and power.
    For now my hack never failed even with 4TB of R3D material to be converted. I think acomputer like this 16-cores coming face even more willing to shoot with EPIC only for the ease of conversion, with the price of a redrocket. you could have 2 pc.
    1 pc with this power do everything on the set.
    However, you and Jeff are great, without you many people would not know so much;)
    luigi
    www.rsi.ch
    EPIC #599 and #668
    SITE
    www.cine5k.ch
    Jul 2009
    Santa Monica
    OK guys, so here is an update with a real test. The turbo boost is definitely not working. I ran a MSRDumper.kext and watched the speeds and they never go over 2900 (2.9GHz), but burst to 3800MHz in windows.
    So I took a 4 min 24 second scene, 5K WS 5:1 and encoded to PR 4444 at 100 quality, 1920x1080, with max depth, no grading.
    Also, it plays back 5K from my raid at 1/2 res without one frame stutter. Full res is still not working, but works with win7 (maybe that speed boost helps).
    You can see the export screenshot here: http://cinespeed.com/ss1.jpg
    Exported 4:24 in 12 minutes.
    Luigi, on your 8 core for example, or anyone else with a 12 core, what would be the encode time for something like this? Without a sample comparison, this test is useless.
    BTW, GTX 690 should be here tomorrow. I assume it wont work with OS X.
    Quote Originally Posted by Joseph S. View Post
    You suck. :'P
    Most likely not...
    I have a GTX690 on order, but I'd say it's a week or two out the way they're trickling in right now. Some seller has them on Amazon for $1500 and I've seen a couple pop up on ebay. Probably not worth it, I guess the current beta drivers for it are kinda flaky.
    HP is definitely off my christmas card list. I paid for 2-day shipping and they shipped my system via ground. And after the multiple delays where it shipped 18 days later than the original estimate. OTOH, Dell was supposed to start taking pre-orders for their new E5 workstations on the first and it still just says "coming soon". FedEx says I'll have it thursday.
    Micron is shipping the rest of my RAM today. Hooray! :)
    ...guess I'd better order a couple more CPUs and the rest of my parts for that other SuperMicro motherboard.
    - Jeff Kilgroe
    Jul 2009
    Santa Monica
    Jeff, if you were a loser like me, sitting on the computer pressing "refresh page" on the EVGA site, you'd get one too.
    Man, you got all the toys, AND you put them to good use.
    BTW, that same clip in RCX was 1 hour 25 minutes with the same settings. With a Redrocket, would that encode in real time? 4 minutes to 4 minutes?
    Aug 2008
    Calgary | Vancouver
    Luigi
    How much did this system cost you for all of the components combined? Maybe you could break them down as well. I know many of us our curious about your new FrankenHack :)
    Best Regards
    Aaron Bernakevitch
    www.4kfilmproduction.com
    Show Reel http://vimeo.com/9036753
    http://www.imdb.com/name/nm2331563/
    RED # 4455 "DUCHESS"
    - Things usually work out better than you plan. When you`re shooting a film you`re so close to it, it rarely lives up to your expectations while you`re there. You always want it to be better, more perfect. When you see a cut, maybe two or three months later, you come to it fresh. It`s generally much better than you thought it would be" RD
    Jul 2009
    Santa Monica
    Quote Originally Posted by Aaron Bernakevitch View Post
    Luigi
    Hi, this is my system. Luigi has helped me in getting it to perform by tweaking the settings remotely. And he has worked hard on it. We just have time differences too since I'm in Los Angeles.
    The pricing is as follows in U.S. currency:
    Supermicro X9DAi motherboard and Chassis are roughly $1000 (board roughly $450)
    Intel CPU's are E5-2690 2.9GHz (roughly $2,000 each)
    Memory is 64GB up to 128GB at roughly $100-120 per 8GB module.
    Video cards and other parts are up to the user.
    Joe
    Mar 2008
    New York City
    yes , and even on a 2009 macro ..
    g
