Thread: Shutter Speed problems at 18o degrees 24fps am i missing something obvious?
Results 1 to 4 of 4
  1. #1 Shutter Speed problems at 18o degrees 24fps am i missing something obvious?
    Having Problems with my Scarlet. Did a test shoot today and found that even at 180 degree shutter at 24 frames (4k hd) using a canon 50mm 1.2. I filmed my friends band practice. and noticed that the look is not the same as film or that of what i would achieve on my 5d at 24 frames. it appears rather fast and sped up. could it be my laptops performance viewing the footage at 1/8th scale or am I missing something obvious?
    Senior Member Domenic Barbero's Avatar
    Nov 2011
    Seattle/Bellingham WA
    was your timebase matching 24fps? or was it in some varispeed mode?
    www.domenicthedp.sqsp.com
    DP/Director/Producer
    Epic-X Dragon 2756 "Krang"
    Contax Zeiss 25,35,50,85,100,180 superspeeds
    tokina 11-16
    canon 70-200
    "I don't know where the artificial stops and the real begins" Andy Warhol
    no it was aa matching timebase
    If suspecting hardware .r3d playback issues, what I would recommend is rendering out a 1080p proxy and playing back the material. If it plays normal, it's likely your hardware having some sort of issue. If it doesn't it's either a bug or your settings were wacky.
    I'm sure there are more possibilities, but this is a quick test to perform.
    phfx.com IMDB
    Scarlet-X #316 "Skully"
Tags for this Thread
View Tag Cloud
