Thread: Varispeed and Audio Workflow
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1 Varispeed and Audio Workflow
    Junior Member Thomas Sidney McCallum's Avatar
    May 2012
    San Francisco, CA
    So we shot an entire feature doc at a variety of different frame-rates on Red Epic and Scarlet. We were run n' gun so didn't have time to resync and slate. We were recording dual system. Now our producer wants to see all these clips in 23.976 FPS rather than 96 or 120. So basically no slow motion. Now our audio guy was recording but the timecode is so far off base that I have been laying out every segment of the shoot in a sequence in Premiere Pro, interpreting the footage in batches ( telling premiere to assume that a clips frame rate is what it was recorded at ) , and matching the audio to each clip..........Its so time consuming and tedious. Luckily its not airing till September so there is still time.
    My hope is that I can export each audio clip to its corresponding video partner and attach it in Red Cine X. Is this the proper workflow? Any advice or anything? Kinda at my wits end....
    Member Nick Barton's Avatar
    Mar 2011
    Wichita, KS
    On what NLE will this project be edited on?
    Nick Barton
    Prestigious Films
    Wichita, KS 67212
    http://www.prestigiousfilms.com
    RED ONE MX #2435 "BLUE"
    May 2012
    San Francisco, CA
    Adobe Premiere Pro CS5.5
    May 2012
    San Francisco, CA
    Unless there is a better workflow in another NLE?
    Jun 2009
    Singapore
    I would recommend looking at DualEyes or PluralEyes, which is a plug-in for PRemiere Pro and other NLE's. It listens to the scratch track, and automatically lines up the high quality audio to match, and outputs a new "clean" timeline.
    Bruce Sharpe demo'ed the new PluralEyes 3.0 at NAB, and the new plug-in and UI looks fast and easy to tweak:
    http://www.dslrnewsshooter.com/2012/...ular-software/
    Jan 2011
    New York, New York
    This would be easily accomplished in fcpX..... "synchronize clips".... 2 seconds..... Done!
    .... It's the future....
    www.KaonMultimedia.com
    Director / Producer
    May 2012
    San Francisco, CA
    Quote Originally Posted by Karl Soule View Post
    There isnt a scratch track on the Epic/Scarlet stuff since its all in Varispeed so I have been matching dialogue by watching mouth movement ( its a Kung Fu Chinese dude ) and trying to match footsteps and other distinct sounds using markers in Premiere Pro.
    CORRECTION:
    It was all shot in varispeed.
    Sincerely,
    T.S. McCallum
    650.868.4969
    San Francisco, CA
    www.seventhmovement.com
    Jun 2009
    Singapore
    Ouch. Without matching time code, or a scratch track, or matching-length audio and video files, I think you're on the right path. They will have to be manually aligned, using human eyes to spot matching A/V events. Even the "Synchronize Clips" command in FCPX won't work in this case. If the audio and video files are the exact same length (audio recorder was jam-synched to the camera, starting/stopping at the same time) then FCPX could be of some help, but if they are different lengths, no. I don't know of any automated tool that will, for example, look for a door slamming on a silent video clip, and find the matching audio event in a separate file. :-(
    May 2012
    San Francisco, CA
    Yeah thats what Im doing now. Im on like hour 10 of the first day of footage.............. sad face facepalm sad face facepalm
    So after this is done....once i align EVERYTHING. Should I head to RCX to attach the audio clips? I mean what if you feed a 96fps clip a 48000khz audio file? lol.............
    Sincerely,
    T.S. McCallum
    650.868.4969
    San Francisco, CA
    Senior Member Elsie N's Avatar
    Oct 2009
    Not sure if this would speed things up for you by getting you in the ball park, but if you could find the end of your audio and corresponding end of your video clip, then lay them both on the Premiere timeline, then adjust speed of the video clip until you get the video and the audio to line up, wouldn't that get your slow-mo back to normal speed and then line up with the audio? Haven't tried anything like that but intuitively it seems like it might work. Then, when you get the two clips lined up you could make your edit cuts on audio and video at the same places.
    One camera is a shoot... two or more is a production.
    L.C. (Elsie) N., omniographer.com, dba nelloProductions, LLC (soon)...looks like a good time to start a business.
Tags for this Thread
View Tag Cloud
