Click here to go to the first RED TEAM post in this thread.   Thread: Beta Camera Build 3.2.8
Page 19 of 55 FirstFirst ... 915161718192021222329 ... LastLast
Results 181 to 190 of 547
  1.   Click here to go to the next RED TEAM post in this thread.
  #181
    We have tracked down the issue with the upgrade process on 3.2.8.
    Until we get a fix in, the recommended upgrade path is to use the force_upgrade process...
    1) create a force_upgrade folder on the top level of your SSD
    2) drag the upgrade.bin file into the force_upgrade folder
    3) insert SSD into camera
    4) power up the camera and wait for upgrade to complete. (the green pwr/rec LED's will flash while upgrading and the camera will automatically shut down)
    everything will be restored to the proper 3.2.8 settings on the next power cycle.
    if you decide to downgrade from 3.2.8 to 3.0.x, we recommend the same procedure.
    -- Matthew Biederman
    Senior Member Andrew Walker's Avatar
    Burbank, CA
    Quote Originally Posted by Trent Lillehaugen View Post
    It is not a separate setting - it is automatic. When you change the REDCODE from the menu you are actually setting the TARGET REDCODE. If you change your frame rate up real high you will see the REDCODE automatically change to the best setting and be colored yellow if it does not match the target. When you change your frame rate back your REDCODE will change back.
    Now that's a helpful feature.
    Check out my new timelapse reel "Illuminate the Heavens" http://vimeo.com/33181548
    Custom Timelapse Shots using Epic and the 5D3
    http://599productions.com
    Aug 2010
    Sweden
    Quote Originally Posted by Glen Powell View Post
    Not sure why some people are having trouble with the Beta upgrade - could be multiple issues and different for everyone; but. I read the install instructions for this one (strangely) and they were different than the last time.
    You need to have the camera on and then install the REDMag and instruct the camera to update - unlike the other updates where the REDMag is in the camera and then you turn it on. Could this be what's hanging some cameras?
    G.
    No, the white screen appears anyway.
    Epic-X #1924 "Solo"
    www.effektfabriken.se
    Oct 2009
    Dresden, Germany
    After a few glitches and "reflashing/reset to default settings"-procedures the new firmware seems to run fine on my scarlet.
    The only thing that i'm missing is 5k HD, it's just not there, every other new resolution is in the list.
    Glitches aside, i know what beta means, this is a really impressive update. Thank you very much RED!
    Scarlet-X #1388
    Canon 24/1.4IIL 50/1.2L 85/1.2IIL 24-105/4.0L | Sigma 35/1.4A
  5.   Click here to go to the next RED TEAM post in this thread.
  #185
    Quote Originally Posted by Per von Koch View Post
    did you use the "upgrade" folder or the "force_upgrade" folder when attempting the install on start-up?
    Sep 2010
    Boise, Idaho
    If we don't see 5k HD should we use the force upgrade option?
    Epic-X #3794
    w: CreativeWaveIdaho.com
    t: @CreativeWaveID
    f: Facebook.com/CreativeWave
    Sep 2010
    Boise, Idaho
    Had some weeeeeird stuff happen during the first upgrade, but the 2nd one seemed to take fine...just missing 5k HD
    Epic-X #3794
    t: @CreativeWaveID
  #188
    Quote Originally Posted by Andrew Allsbury View Post
    No, 5K HD was not included in the scarlet upgrade. The max frame-rate would have had the same 12 fps limitation.
    Sep 2010
    Boise, Idaho
    Thank you!
    Epic-X #3794
    t: @CreativeWaveID
    Feb 2010
    Helsinki, Finland
    Quote Originally Posted by TheBied View Post
    5K HD would still be useful for shooting 16:9 timelapse on the Scarlet. Any chance of seeing it in the next firmware? 5K WS would be nice to see as well.
