Thread: Problems with workflow #2 Offline to Prores Reconform to RED QT Media
Results 1 to 3 of 3
  1. #1 Problems with workflow #2 Offline to Prores Reconform to RED QT Media
    Junior Member
    Apr 2012
    I followed all the instructions on the White papper, except step one. So instead of using fcp as I used to, I ended up using redcinex to transcode to Prores.
    Im now stuck not knowing the best way to reconform, fcp will not recognize the batch capture command since I used RedCinex.
    Can someone point me to another workflow option to reconform and send to color?
    If you could send me a link, article anything explaining the steps you would be saving me from my stupidity.
    A little desperate. Thanks
    Senior Member Jarek Zabczynski's Avatar
    Poughkeepsie, NY
    I'm not an expert on this part so someone can correct me. But I think you export an XML of your sequence out of FCP and open that up in REDCINEX to conform to R3D. Then you export a new XML from RCX to use in Color. I don't think you want to conform to your QT proxies.
    Shoot for the Impossible...Then do it.
    Jarek Zabczynski
    Director / Editor / Cinematographer
    Scarlet X - #525 | Epic X - #??? | www.jarek.com | WE'LL BE ALRIGHT (Music Video) | INCREDIBLE (Scarlet Music Video)
    Junior Member
    Apr 2012
    Thanks Jarek! tried that, also tried edls to redcine and color even tried the cinema tool way.
    I think something might be wrong with the files nothing is working except doing it manually in FCP. Its fine for a 30sec trailer but for the music video with all the cuts its going to be painfull.
    Heard something about Storm being a good option to re conform, as anyone tried it and if you recommend it can you point me to a resource on how to do it?
